跳转到主内容
加入维修社区 - 创建账户
MAGNAVOX MDV2300 Motherboard Replacement
你所需要的
  1. MAGNAVOX MDV2300 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Before you begin, examine the device. Ensure it is unplugged from the wall.
  2. MAGNAVOX MDV2300 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the two screws on the top panel.
  3. MAGNAVOX MDV2300 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the top panel from the device by pulling then lifting it off.
  4. MAGNAVOX MDV2300 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Identify the motherboard.
  5. MAGNAVOX MDV2300 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Carefully unplug the wires from the motherboard component. Do not be afraid to use extra force when tugging; the wires are strong and should not tear.
    • Remove the motherboard from the device by lifting it from the base with your fingers.
  6. MAGNAVOX MDV2300 Motherboard Replacement: 步骤 7 中的图像 1,1
    • When installing the motherboard back into the device, make sure the wires are snug in their casings.
结论
另外一个人完成了本指南。
Justin
于01/21/15注册
298 声望
创作了2篇指南
团队
Penn State, Team 1-41, Kaschak Winter 2015 Penn State, Team 1-41, Kaschak Winter 2015 的会员
PSU-KASCHAK-W15S1G41
4 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 31
总计 1,236
