跳转到主内容
Lorex LHV210800 Motherboard Replacement
你所需要的
  1. Lorex LHV210800 Motherboard Replacement, Upper Case: 步骤 1 中的图像 1,3 Lorex LHV210800 Motherboard Replacement, Upper Case: 步骤 1 中的图像 2,3 Lorex LHV210800 Motherboard Replacement, Upper Case: 步骤 1 中的图像 3,3
    • Before beginning, disconnect the DVR from power and unplug all peripheries.
    • Remove each of the two 1 cm screws on the right and left sides of the DVR with a Phillips screwdriver.
  2. Lorex LHV210800 Motherboard Replacement: 步骤 2 中的图像 1,2 Lorex LHV210800 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the four 1 cm Phillips screws on the rear panel.
    • Do not unscrew the screw connected to the lower case.
  3. Lorex LHV210800 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Lift up and remove the top cover.
  4. Lorex LHV210800 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 Lorex LHV210800 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Unscrew the 1cm hex screws with the driver and a size 8 hex socket.
    • Unplug the cord from the socket in the motherboard.
  5. Lorex LHV210800 Motherboard Replacement: 步骤 5 中的图像 1,3 Lorex LHV210800 Motherboard Replacement: 步骤 5 中的图像 2,3 Lorex LHV210800 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Remove the two 1cm screws from the back panel.
    • This makes it easier to slide out with no issue.
  6. Lorex LHV210800 Motherboard Replacement: 步骤 6 中的图像 1,2 Lorex LHV210800 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Once all the screws are off the back panel, remove the power source.
    • The power source would be the white box with the R/B/G cables attached, along with the blue and other white box with R/B/B/Y cords.
  7. Lorex LHV210800 Motherboard Replacement: 步骤 7 中的图像 1,2 Lorex LHV210800 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove this pin in order to take off the fan.
    • Remove the fan in order to access the motherboard.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Maxwell Cash
于02/19/25注册
387 声望
创作了3篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 206
