当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the two 8 mm Phillips #0 screws on the back cover.
The motherboard connects the two covers together. DO NOT separate the two yet.
There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
DO NOT detach the wire connecting the motherboard to the front cover.
Remove the two 8mm Phillips#0 screws on the back of the motherboard.
Remove the camera from the motherboard by desoldering the two connections as shown.
Follow this link to learn how to properly solder and desolder your parts.
取消:我没有完成这个指南。
与9其他贡献者
于04/18/13注册
63 声望
创作了2篇指南
徽章: 6
+ 3更多徽章
CPSU-AMIDO-S13S12G34
4 名成员
创作了16篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 19
总计 2,367
