跳转到主内容
Logitech Webcam Pro 9000 Camera Replacement
你所需要的
  1. Logitech Webcam Pro 9000 Camera Replacement, Front and Back Cover: 步骤 1 中的图像 1,2 Logitech Webcam Pro 9000 Camera Replacement, Front and Back Cover: 步骤 1 中的图像 2,2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Camera Replacement: 步骤 2 中的图像 1,2 Logitech Webcam Pro 9000 Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 Camera Replacement, Camera: 步骤 3 中的图像 1,1
    • Remove the two 8mm Phillips#0 screws on the back of the motherboard.
  4. Logitech Webcam Pro 9000 Camera Replacement: 步骤 4 中的图像 1,3 Logitech Webcam Pro 9000 Camera Replacement: 步骤 4 中的图像 2,3 Logitech Webcam Pro 9000 Camera Replacement: 步骤 4 中的图像 3,3
    • Remove the camera from the motherboard by desoldering the two connections as shown.
    • Follow this link to learn how to properly solder and desolder your parts.
结论
nieko
于04/18/13注册
63 声望
创作了2篇指南
团队
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 的会员
CPSU-AMIDO-S13S12G34
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 2,588
