你所需要的
Use a metal spudger to pry open the power button cover.
Once the power button cover is slightly opened, use your fingers to remove the power button cover.
Remove the fifteen 13.0 mm screws with a #0 Phillips from the side of the device containing two speakers.
Separate the two halves by gently pulling them apart.
3等其他人完成本指南。
一条评论
Could you recommend anywhere to find the correct replacement tweeters & drivers?
