跳转到主内容
Logitech UE BOOM 2 Battery Replacement
你所需要的
  1. Logitech UE BOOM 2 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Logitech UE BOOM 2 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. Logitech UE BOOM 2 Battery Replacement: 步骤 2 中的图像 1,2 Logitech UE BOOM 2 Battery Replacement: 步骤 2 中的图像 2,2
    • After the D-ring has been removed, remove the rubber port cover.
  3. Logitech UE BOOM 2 Battery Replacement: 步骤 3 中的图像 1,3 Logitech UE BOOM 2 Battery Replacement: 步骤 3 中的图像 2,3 Logitech UE BOOM 2 Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
    • It is not necessary to entirely remove the rubber stripping. Simply popping the cap is adequate.
  4. Logitech UE BOOM 2 Battery Replacement: 步骤 4 中的图像 1,1
    • Continue removing the rubber stripping down the side if you intend to replace it.
  5. Logitech UE BOOM 2 Battery Replacement: 步骤 5 中的图像 1,3 Logitech UE BOOM 2 Battery Replacement: 步骤 5 中的图像 2,3 Logitech UE BOOM 2 Battery Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #2 screwdriver to unscrew the four 15mm screws on the bottom of the speaker. DO NOT OPEN SIDE WITH RED CAP (AS SHOWN IN SOME IMAGES), BATTERY IS ON OPPOSITE SIDE
    • Use a metal spudger to pry up the plastic cap.
  6. Logitech UE BOOM 2 Battery Replacement: 步骤 6 中的图像 1,2 Logitech UE BOOM 2 Battery Replacement: 步骤 6 中的图像 2,2
    • Carefully unseat the battery cable from the retaining posts.
    • Squeeze the small black clip on the battery connector, then lift the connector to unplug it.
    • Slowly pull out the battery, and handle with care.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
52等其他人完成本指南。
Brandon Yowakim
于01/18/18注册
1,265 声望
创作了2篇指南
27指南评论
what kind of battery ?and do you have a link to buy one
wrig5235 - 回复
I was looking for a battery replacement all over the place. Came up with this site that carries parts for the Boom 2:
https://www.joesge.com/products/ue-ultim...
Frederic - 回复
Why is this set to difficult though? It doesn’t look THAT hard… And will this affect waterproofing of the feature?
Frederic - 回复
Because you do not simply stick the plunger in and pop those tabs. They are a force of evil and I even bent my metal tools to open mine.
Joseph Murphy -
It isn't that hard if you've done a couple of repairs, although you gotta work slow and really make sure you got yourself like 3-4 spudger like items (butter knife) and look at reference images where the tabs are. Btw. You don't need to remove more than the bottom plastics and the plate with 4 screws to change the battery. Managed to change my battery while not damaging a single plastic tab
Lucas Schießl -
添加评论
浏览统计数据:
过去 24 小时: 30
过去 7 天: 289
过去 30 天: 1,227
总计 141,611
