跳转到主内容
Logitech Signature AI Edition M750 Battery Replacement
你所需要的
  1. Logitech Signature AI Edition M750 Battery Replacement, Turn off your mouse: 步骤 1 中的图像 1,1
    • Before starting, flip the power switch on the bottom of your mouse to the left, so it's in the OFF position.
  2. Logitech Signature AI Edition M750 Battery Replacement, Remove the battery cover: 步骤 2 中的图像 1,3 Logitech Signature AI Edition M750 Battery Replacement, Remove the battery cover: 步骤 2 中的图像 2,3 Logitech Signature AI Edition M750 Battery Replacement, Remove the battery cover: 步骤 2 中的图像 3,3
    • Press down on the battery cover with your thumb and slide it away from the mouse to unclip it.
    • Remove the battery cover.
  3. Logitech Signature AI Edition M750 Battery Replacement, Remove the battery: 步骤 3 中的图像 1,3 Logitech Signature AI Edition M750 Battery Replacement, Remove the battery: 步骤 3 中的图像 2,3 Logitech Signature AI Edition M750 Battery Replacement, Remove the battery: 步骤 3 中的图像 3,3
    • Use your fingers to lift the end of the battery and slide it out of its recess.
    • During reassembly, slide the battery in negative (-) end first, as shown on the sticker in the recess.
结论
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
另外一个人完成了本指南。
Spencer Day
于09/14/22注册
153,502 声望
创作了1,024篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 21
总计 93
