跳转到主内容
加入维修社区 - 创建账户
Logitech M275 Scroll Wheel Replacement
你所需要的
  1. Logitech M275 Scroll Wheel Replacement, Scroll Wheel: 步骤 1 中的图像 1,3 Logitech M275 Scroll Wheel Replacement, Scroll Wheel: 步骤 1 中的图像 2,3 Logitech M275 Scroll Wheel Replacement, Scroll Wheel: 步骤 1 中的图像 3,3
    • Flip the mouse over.
    • With your fingers, gently press down and remove the battery cover.
    • Remove the battery and the USB receiver from the mouse.
  2. Logitech M275 Scroll Wheel Replacement: 步骤 2 中的图像 1,2 Logitech M275 Scroll Wheel Replacement: 步骤 2 中的图像 2,2
    • Remove the sticker at the bottom of the battery compartment.
    • Use a Phillips screwdriver to remove the single screws at the bottom of the battery compartment.
  3. Logitech M275 Scroll Wheel Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the top half of the mouse cover.
  4. Logitech M275 Scroll Wheel Replacement: 步骤 4 中的图像 1,2 Logitech M275 Scroll Wheel Replacement: 步骤 4 中的图像 2,2
    • Use a spudger or screwdriver to carefully apply upward pressure around each side of the circuit board until the whole piece slides out of the bottom.
  5. Logitech M275 Scroll Wheel Replacement: 步骤 5 中的图像 1,1
    • Using a soft cloth, gently remove dust and small debris.
  6. Logitech M275 Scroll Wheel Replacement: 步骤 6 中的图像 1,3 Logitech M275 Scroll Wheel Replacement: 步骤 6 中的图像 2,3 Logitech M275 Scroll Wheel Replacement: 步骤 6 中的图像 3,3
    • Carefully remove the wheel from its axis and replace it with the new wheel.
  7. Logitech M275 Scroll Wheel Replacement: 步骤 7 中的图像 1,3 Logitech M275 Scroll Wheel Replacement: 步骤 7 中的图像 2,3 Logitech M275 Scroll Wheel Replacement: 步骤 7 中的图像 3,3
    • Ensure that the new scroll wheel is aligned with the encoder.
    • Make sure that the new scroll wheel spins and clicks into place.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Adrianna Doan
于05/12/25注册
145 声望
撰写一个指南
团队
UC Davis, Team 2-4, Whithaus Spring 2025 UC Davis, Team 2-4, Whithaus Spring 2025 的会员
UCD-WHITHAUS-S25S2G4
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 21
过去 30 天: 75
总计 600
