跳转到主内容
Logitech M100 Switch Replacement
你所需要的
  1. Logitech M100 Switch Replacement, Switches: 步骤 1 中的图像 1,1
    • Disconnect the mouse from any devices before attempting to remove any parts or starting the repair.
    • Flip your mouse over so the bottom is facing up.
  2. Logitech M100 Switch Replacement: 步骤 2 中的图像 1,1
    • Use a small Phillips #00 screwdriver to remove the single screw at the bottom of the mouse.
  3. Logitech M100 Switch Replacement: 步骤 3 中的图像 1,2 Logitech M100 Switch Replacement: 步骤 3 中的图像 2,2
    • Turn your mouse over so it is facing right side up.
    • Use a spudger or your hands to carefully separate the top from the bottom housing.
    • It's important to remove the top housing while leaving the bottom in place, as the scroll wheel and other internal components may fall out otherwise.
  4. Logitech M100 Switch Replacement: 步骤 4 中的图像 1,1
    • Remove the external cable from the slot at the front of the mouse.
  5. Logitech M100 Switch Replacement: 步骤 5 中的图像 1,3 Logitech M100 Switch Replacement: 步骤 5 中的图像 2,3 Logitech M100 Switch Replacement: 步骤 5 中的图像 3,3
    • Remove the circuit board from the mouse by pushing down at the back and lifting up at the front.
  6. Logitech M100 Switch Replacement: 步骤 6 中的图像 1,2 Logitech M100 Switch Replacement: 步骤 6 中的图像 2,2
    • Lift the scroll wheel from the board.
    • There should be a total of four parts that make up the scroll wheel.
  7. Logitech M100 Switch Replacement: 步骤 7 中的图像 1,1
    • Pull the USB cable away from the connector in the same direction as the individual wires to remove it from the motherboard.
    • This step may prove difficult with just your hands. Use a spudger if you need to.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  8. Logitech M100 Switch Replacement: 步骤 8 中的图像 1,1
    • Find a suitable method to hold the circuit board in place so you don't have to hold it in your hands.
    • Use a small vice to keep it in place or helping hands for this next step.
  9. Logitech M100 Switch Replacement: 步骤 9 中的图像 1,3 Logitech M100 Switch Replacement: 步骤 9 中的图像 2,3 Logitech M100 Switch Replacement: 步骤 9 中的图像 3,3
    • Use a soldering iron to heat the solder points securing both switches, and remove the switches using tweezers.
    • The soldering iron and the solder holding the switch in place will be very hot and can burn you.
  10. Logitech M100 Switch Replacement: 步骤 10 中的图像 1,3 Logitech M100 Switch Replacement: 步骤 10 中的图像 2,3 Logitech M100 Switch Replacement: 步骤 10 中的图像 3,3
    • Replace each switch and solder it to the circuit board.
    • The soldering wire may conduct heat up to the hand holding it.
    • Be sure to work in a well ventilated space as the solder may emit smoke.
    • You can use tape to hold the switch in place while soldering.
  11. Logitech M100 Switch Replacement: 步骤 11 中的图像 1,2 Logitech M100 Switch Replacement: 步骤 11 中的图像 2,2
    • Reassemble the mouse by following steps 2-7 in reverse order.
结论
Congratulations, you have now replaced the clickers on your mouse and can continue using it!
2等其他人完成本指南。
团队
CSU Los Angeles, Team 7-2, Grodsky Spring 2024 CSU Los Angeles, Team 7-2, Grodsky Spring 2024 的会员
CSULA-GRODSKY-S24S7G2
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 47
总计 729
