跳转到主内容
Logitech K800 Battery Replacement
你所需要的
  1. Logitech K800 Battery Replacement, Remove the rear compartment screw: 步骤 1 中的图像 1,1
    • Use a Phillips driver to remove the 5.7 mm screw securing the rear compartment.
  2. Logitech K800 Battery Replacement, Remove the rear compartment: 步骤 2 中的图像 1,3 Logitech K800 Battery Replacement, Remove the rear compartment: 步骤 2 中的图像 2,3 Logitech K800 Battery Replacement, Remove the rear compartment: 步骤 2 中的图像 3,3
    • Slide the rear compartment toward the top of the keyboard and remove it.
  3. Logitech K800 Battery Replacement, Pry up the rear cover: 步骤 3 中的图像 1,2 Logitech K800 Battery Replacement, Pry up the rear cover: 步骤 3 中的图像 2,2
    • Slide the edge of an opening tool underneath the bottom edge of the rear cover and pry the cover up to create a gap.
    • You will pry the rear cover away from the keyboard for the next two steps. There are adhesive and clips holding the cover down that will make prying difficult.
  4. Logitech K800 Battery Replacement, Continue prying the rear cover: 步骤 4 中的图像 1,3 Logitech K800 Battery Replacement, Continue prying the rear cover: 步骤 4 中的图像 2,3 Logitech K800 Battery Replacement, Continue prying the rear cover: 步骤 4 中的图像 3,3
    • Keeping the opening tool under the rear cover, slide it around the right side of the cover to separate the adhesive and clips on that side.
    • It may help to push the tool farther under the cover, toward the middle of the keyboard.
  5. Logitech K800 Battery Replacement: 步骤 5 中的图像 1,3 Logitech K800 Battery Replacement: 步骤 5 中的图像 2,3 Logitech K800 Battery Replacement: 步骤 5 中的图像 3,3
    • Keeping the opening tool under the rear cover, slide it around the left side of the cover to separate the adhesive and clips on that side.
  6. Logitech K800 Battery Replacement, Remove the rear cover: 步骤 6 中的图像 1,3 Logitech K800 Battery Replacement, Remove the rear cover: 步骤 6 中的图像 2,3 Logitech K800 Battery Replacement, Remove the rear cover: 步骤 6 中的图像 3,3
    • Hinge the bottom of the rear cover up until the clips along the top edge of the cover disengage, then lift the whole cover up to remove it.
  7. Logitech K800 Battery Replacement, Reassembly tip: 步骤 7 中的图像 1,3 Logitech K800 Battery Replacement, Reassembly tip: 步骤 7 中的图像 2,3 Logitech K800 Battery Replacement, Reassembly tip: 步骤 7 中的图像 3,3
    • During reassembly, start by sliding the clips along the top edge of the rear cover into place.
    • Place the top edge of the cover slightly above the top edge of the keyboard, then slide it down into place.
  8. Logitech K800 Battery Replacement, Remove the front cover: 步骤 8 中的图像 1,1
    • Use a Phillips driver to remove the twelve 5.7 mm screws securing the front cover.
    • Use a Phillips driver to remove the three 4.7 mm screws securing the keyboard keys.
  9. Logitech K800 Battery Replacement: 步骤 9 中的图像 1,2 Logitech K800 Battery Replacement: 步骤 9 中的图像 2,2
    • Slide an opening tool into the seam along one edge of the front cover. Pry the cover up to create a gap.
  10. Logitech K800 Battery Replacement: 步骤 10 中的图像 1,3 Logitech K800 Battery Replacement: 步骤 10 中的图像 2,3 Logitech K800 Battery Replacement: 步骤 10 中的图像 3,3
    • Slide the opening tool around the perimeter of the front case to release all the clips securing the front cover.
  11. Logitech K800 Battery Replacement: 步骤 11 中的图像 1,1
    • With all the clips released, lift the front cover and remove it.
  12. Logitech K800 Battery Replacement, Unscrew the keyboard keys: 步骤 12 中的图像 1,1
    • Use a Phillips driver to remove the six screws securing the keyboard keys.
    • Four 5.7 mm screws
    • Two 4.7 mm screws
  13. Logitech K800 Battery Replacement, Move the keyboard keys out of the way: 步骤 13 中的图像 1,2 Logitech K800 Battery Replacement, Move the keyboard keys out of the way: 步骤 13 中的图像 2,2
    • Gently flip the keyboard keys up and over the top of the keyboard to reveal the backlight.
    • Take care not to strain or crease the keyboard keys ribbon cable.
  14. Logitech K800 Battery Replacement, Move the backlight out of the way: 步骤 14 中的图像 1,2 Logitech K800 Battery Replacement, Move the backlight out of the way: 步骤 14 中的图像 2,2
    • Gently flip the backlight up and over the top of the keyboard to reveal the keyboard backplate.
    • Take care not to strain or crease the backlight ribbon cable.
  15. Logitech K800 Battery Replacement, Remove the backplate: 步骤 15 中的图像 1,3 Logitech K800 Battery Replacement, Remove the backplate: 步骤 15 中的图像 2,3 Logitech K800 Battery Replacement, Remove the backplate: 步骤 15 中的图像 3,3
    • Grasp one end of the backplate and lift it off of the keyboard case.
    • Remove the backplate.
  16. Logitech K800 Battery Replacement, Disconnect the battery: 步骤 16 中的图像 1,2 Logitech K800 Battery Replacement, Disconnect the battery: 步骤 16 中的图像 2,2
    • Grasp the top edge of the battery connector with your fingers or a tweezer.
    • Pull the connector straight out of its socket on the motherboard.
  17. Logitech K800 Battery Replacement, Free the battery cable: 步骤 17 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the tape securing the battery cable to the case.
  18. Logitech K800 Battery Replacement: 步骤 18 中的图像 1,3 Logitech K800 Battery Replacement: 步骤 18 中的图像 2,3 Logitech K800 Battery Replacement: 步骤 18 中的图像 3,3
    • Pull the battery cable out of its slots in the keyboard case.
  19. Logitech K800 Battery Replacement, Remove the battery: 步骤 19 中的图像 1,1
    • Heat an iOpener and apply it to the keyboard case underneath the battery for two minutes.
  20. Logitech K800 Battery Replacement: 步骤 20 中的图像 1,3 Logitech K800 Battery Replacement: 步骤 20 中的图像 2,3 Logitech K800 Battery Replacement: 步骤 20 中的图像 3,3
    • Use a spudger to pry the battery away from the keyboard case.
    • If you encounter significant resistance, stop and apply more heat.
  21. Logitech K800 Battery Replacement: 步骤 21 中的图像 1,1
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • During reassembly, you may use the old battery adhesive with your new battery. Alternatively, you may clean any old adhesive residue from the battery compartment using high-concentration isopropyl alcohol and install new adhesive from a follow pre-cut adhesive sheet.
结论
15等其他人完成本指南。
Adam O'Camb
于04/11/15注册
198,503 声望
创作了416篇指南
12条评论
the original took 2 lithium AA rechargeables. their update just creates ewaste
Kevin Weldon - 回复
not lithium! Just standard Ni-MH AA's. I was pretty disappointed when I bought the second keyboard (the fist one was already pretty beaten up) only to discover that below the battery door there is just plastic and no battery! bastards... I used the keyboard from time to time as 2xAA charger (as most of the time it was connected to power) and I swapped those fully charged batteries with discharged ones from other devices that take 2xAAs aswell
Nellinka Fotky -
Do you have a part number for the replacement battery?
Ryker Bailey - 回复
The part in the canadianbatteries.com link is not the correct part for this keyboard.
The correct PN is 533-000141, this has longer leads on the battery and the battery capacity is larger than the one linked. Aliexpress is the only place I have been able to locate a new one.
Ryker Bailey -
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 129
过去 30 天: 609
总计 20,043
