跳转到主内容
Logitech Harmony Smart Control Hub Light Bulb Replacement
你所需要的
  1. Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: 步骤 1 中的图像 1,2 Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: 步骤 1 中的图像 2,2
    • Use a spudger to lift up one of the rubber pads on the bottom of the hub.
    • Pull back the rubber pad and remove it. This will expose the screws on the bottom of the device.
    • Repeat for the second rubber pad.
  2. Logitech Harmony Smart Control Hub Light Bulb Replacement: 步骤 2 中的图像 1,2 Logitech Harmony Smart Control Hub Light Bulb Replacement: 步骤 2 中的图像 2,2
    • Use a PH00 screwdriver bit to remove the four 6mm Phillips screws on the bottom of the device.
  3. Logitech Harmony Smart Control Hub Light Bulb Replacement: 步骤 3 中的图像 1,2 Logitech Harmony Smart Control Hub Light Bulb Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to separate the top and bottom pieces of the device.
  4. Logitech Harmony Smart Control Hub Light Bulb Replacement: 步骤 4 中的图像 1,2 Logitech Harmony Smart Control Hub Light Bulb Replacement: 步骤 4 中的图像 2,2
    • Use the PH00 screwdriver bit to unscrew the three 4mm Phillips screws on the control board.
  5. Logitech Harmony Smart Control Hub Light Bulb Replacement: 步骤 5 中的图像 1,2 Logitech Harmony Smart Control Hub Light Bulb Replacement: 步骤 5 中的图像 2,2
    • Place the end of the opening tool under the yellow corner of the circuit board as shown.
    • Gently push upward to pry the board from its housing.
  6. Logitech Harmony Smart Control Hub Light Bulb Replacement: 步骤 6 中的图像 1,3 Logitech Harmony Smart Control Hub Light Bulb Replacement: 步骤 6 中的图像 2,3 Logitech Harmony Smart Control Hub Light Bulb Replacement: 步骤 6 中的图像 3,3
    • Determine which of the five bulbs are defective.
    • Turn the board over to expose the bulb solder.
    • Using a soldering iron, remove the solder and bulb. Replace with a new bulb and re-solder.
结论
2等其他人完成本指南。
Josh Hendricks
于09/17/15注册
464 声望
创作了4篇指南
团队
IUPUI, Team 3-2, Harley Fall 2015 IUPUI, Team 3-2, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S3G2
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 8
总计 655
