跳转到主内容
Logitech Harmony Smart Control Charging Port Replacement
你所需要的
  1. Logitech Harmony Smart Control Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,2 Logitech Harmony Smart Control Charging Port Replacement, Charging Port: 步骤 1 中的图像 2,2
    • Use the plastic opening tool to lift up the rubber pad.
    • With your fingers, pull back the rubber pad. This will expose the screw holes on the bottom of the device.
    • Repeat the step above for the second rubber pad on the bottom of the hub.
  2. Logitech Harmony Smart Control Charging Port Replacement: 步骤 2 中的图像 1,2 Logitech Harmony Smart Control Charging Port Replacement: 步骤 2 中的图像 2,2
    • Using the PH00 bit, remove the four 6mm Phillips screws
  3. Logitech Harmony Smart Control Charging Port Replacement: 步骤 3 中的图像 1,2 Logitech Harmony Smart Control Charging Port Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to pry open and separate the pieces of plastic from each other.
  4. Logitech Harmony Smart Control Charging Port Replacement: 步骤 4 中的图像 1,2 Logitech Harmony Smart Control Charging Port Replacement: 步骤 4 中的图像 2,2
    • Using the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Charging Port Replacement: 步骤 5 中的图像 1,3 Logitech Harmony Smart Control Charging Port Replacement: 步骤 5 中的图像 2,3 Logitech Harmony Smart Control Charging Port Replacement: 步骤 5 中的图像 3,3
    • Starting at the yellow corner, use a plastic opening tool to pry the circuit board from the housing.
  6. Logitech Harmony Smart Control Charging Port Replacement: 步骤 6 中的图像 1,3 Logitech Harmony Smart Control Charging Port Replacement: 步骤 6 中的图像 2,3 Logitech Harmony Smart Control Charging Port Replacement: 步骤 6 中的图像 3,3
    • Locate the defective charging port.
    • Turn the circuit board over to expose the charging solder.
    • Using a soldering iron, remove the solder and the charging port. Install a new charging port and solder.
结论
另外一个人完成了本指南。
Josh Hendricks
于09/17/15注册
464 声望
创作了4篇指南
团队
IUPUI, Team 3-2, Harley Fall 2015 IUPUI, Team 3-2, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S3G2
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 862
