跳转到主内容
Logitech Harmony Smart Control Battery Contact Replacement
你所需要的
  1. Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: 步骤 1 中的图像 1,2 Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: 步骤 1 中的图像 2,2
    • Use both thumbs to slide the grooved cover off of the remote
    • Once the cover is off, remove the battery.
  2. Logitech Harmony Smart Control Battery Contact  Replacement: 步骤 2 中的图像 1,2 Logitech Harmony Smart Control Battery Contact  Replacement: 步骤 2 中的图像 2,2
    • Locate both of the 4mm Phillips screws on the remote. Using the PH00 bit, remove the screws.
  3. Logitech Harmony Smart Control Battery Contact  Replacement: 步骤 3 中的图像 1,3 Logitech Harmony Smart Control Battery Contact  Replacement: 步骤 3 中的图像 2,3 Logitech Harmony Smart Control Battery Contact  Replacement: 步骤 3 中的图像 3,3
    • Use a flat screwdriver or a prying tool to split the remote and separate the two pieces. Start from the bottom.
  4. Logitech Harmony Smart Control Battery Contact  Replacement: 步骤 4 中的图像 1,2 Logitech Harmony Smart Control Battery Contact  Replacement: 步骤 4 中的图像 2,2
    • Using the metal piece from the housing, pry the circuit board upwards. Do not disconnect it from the board.
    • Slide the circuit board out from the housing .
  5. Logitech Harmony Smart Control Battery Contact  Replacement: 步骤 5 中的图像 1,1
    • Locate the battery contacts on the circuit board.
    • Using a soldering iron, remove the old solder and the battery contacts. Install new battery contacts and solder them.
结论
Josh Hendricks
于09/17/15注册
464 声望
创作了4篇指南
团队
IUPUI, Team 3-2, Harley Fall 2015 IUPUI, Team 3-2, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S3G2
4 名成员
创作了5篇指南
一条评论
do you know where can i buy the springs?
IOANNIS KARAKOGLOU - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 19
总计 4,944
