跳转到主内容
Logitech G920 Driving Force XYAB Buttons Replacement
你所需要的
  1. Logitech G920 Driving Force XYAB Buttons Replacement, Steering Wheel Motherboard: 步骤 1 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
    • Only three of the five screws are visible from each side of the wheel due to the center unit.
  2. Logitech G920 Driving Force XYAB Buttons Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
  3. Logitech G920 Driving Force XYAB Buttons Replacement: 步骤 3 中的图像 1,2 Logitech G920 Driving Force XYAB Buttons Replacement: 步骤 3 中的图像 2,2
    • Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
    • Remove the face plate from the steering wheel.
  4. Logitech G920 Driving Force XYAB Buttons Replacement: 步骤 4 中的图像 1,2 Logitech G920 Driving Force XYAB Buttons Replacement: 步骤 4 中的图像 2,2
    • Remove the wheel from the main steering wheel console.
    • Ensure this is done carefully as to not damage the connection wire.
  5. Logitech G920 Driving Force XYAB Buttons Replacement: 步骤 5 中的图像 1,2 Logitech G920 Driving Force XYAB Buttons Replacement: 步骤 5 中的图像 2,2
    • Remove the eight 7.5 mm screws holding the steering wheel motherboard in place using a Phillips #0 screwdriver.
    • Remove the steering wheel motherboard.
  6. Logitech G920 Driving Force XYAB Buttons Replacement, XYAB Buttons: 步骤 6 中的图像 1,1
    • Remove the XYAB buttons from the back of the steering wheel.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 39
总计 784
