跳转到主内容
Logitech G915 TKL Keyswitch Replacement
你所需要的
  1. Logitech G915 TKL Keyswitch Replacement, Keyswitch: 步骤 1 中的图像 1,2 Logitech G915 TKL Keyswitch Replacement, Keyswitch: 步骤 1 中的图像 2,2
    • Remove all of the keycaps on the keyboard.
    • Unscrew the 2mm #00 Phillips screws circled in the picture provided.
  2. Logitech G915 TKL Keyswitch Replacement: 步骤 2 中的图像 1,2 Logitech G915 TKL Keyswitch Replacement: 步骤 2 中的图像 2,2
    • Turn the keyboard around and peel back the Logitech sticker near the top center of the keyboard, as well as the plastic layer underneath.
    • Unscrew the two 2.5mm #0 Phillips screws circled in the picture provided.
    • Remove the backplate by grabbing the notch to the right and pulling up.
  3. Logitech G915 TKL Keyswitch Replacement: 步骤 3 中的图像 1,2 Logitech G915 TKL Keyswitch Replacement: 步骤 3 中的图像 2,2
    • Remove the foam strips shown in the picture provided.
    • Unscrew all the 2mm #00 Phillips screws on the back of the keyboard circled in the picture provided.
  4. Logitech G915 TKL Keyswitch Replacement: 步骤 4 中的图像 1,1
    • Remove the casing on the keyboard to reveal the motherboard.
  5. Logitech G915 TKL Keyswitch Replacement: 步骤 5 中的图像 1,1
    • Find the corresponding soldering point for the keyswitch you wish to replace.
  6. Logitech G915 TKL Keyswitch Replacement: 步骤 6 中的图像 1,1
    • Carefully heat the soldering wire.
    • Place the wire near the keyswitch's solder points so that it can be desoldered by the wire.
    • Insert your new keyswitch in place of the old one.
    • Solder the new keyswitch into place.
结论
Ethan Bedard
于03/13/23注册
485 声望
创作了3篇指南
团队
UMass Dartmouth, Team 3-6, Petersen Spring 2023 UMass Dartmouth, Team 3-6, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S3G6
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 28
过去 7 天: 206
过去 30 天: 953
总计 12,490
