简介
If you can no longer charge your Logitech G733 headset and you've ruled out a faulty battery, the charging port may need to be replaced. Accessing the power button requires taking off the circuit board, you can also access many other components with these same steps. For this guide, you will need a Phillips #000 screwdriver, a T4 Torx screwdriver, and a soldering iron. This is a difficult replacement. Soldering experience is advised.
你所需要的
Gently begin to pull the left ear pad off, starting from the top.
Slide your finger around the edges until it releases entirely.
