简介
Follow this guide to remove and replace the battery on a Logitech G533 wireless gaming headset. You may need to do this repair if the battery no longer holds a charge.
If your battery is swollen, take appropriate precautions.
Shift the power switch down to the OFF position to turn off the headset.
Place the headset on your work surface so that the microphone is facing up.
Rotate the ear cups 90 degrees so that the mesh ear pads are laying on the table and the Logitech G logo is facing up.
Use two fingers to rotate the battery cover on the right ear cup counterclockwise.
Use your finger to lift up the bottom edge of the battery by the tab between the two clips.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Logitech G533 Answers community for help.
6等其他人完成本指南。
一条评论
Grazie davvero, avevo bisogno da tempo di sostituire la batteria delle mie G533 e adesso l'ho fatto in meno di 2 minuti e senza nessun tipo di problema
