跳转到主内容
Logic Board Disconnection
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Logic Board Disconnection, Disconnect the logic board: 步骤 1 中的图像 1,2 Logic Board Disconnection, Disconnect the logic board: 步骤 1 中的图像 2,2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad connector bracket.
    • Depending on the condition of your bits, a T4 Torx driver may fit better.
    • Remove the trackpad connector bracket.
  2. Logic Board Disconnection: 步骤 2 中的图像 1,2 Logic Board Disconnection: 步骤 2 中的图像 2,2
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
  3. Logic Board Disconnection: 步骤 3 中的图像 1,3 Logic Board Disconnection: 步骤 3 中的图像 2,3 Logic Board Disconnection: 步骤 3 中的图像 3,3
    • If the left speaker is already disconnected, skip this step.
    • Slide the tip of a spudger underneath the left speaker cable and pry straight up to disconnect the speaker.
    • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
  4. Logic Board Disconnection: 步骤 4 中的图像 1,2 Logic Board Disconnection: 步骤 4 中的图像 2,2
    • Use a T3 Torx driver to remove the two 1.3 mm screws securing the USB-C port connector bracket.
    • Remove the USB-C connector bracket.
  5. Logic Board Disconnection: 步骤 5 中的图像 1,2 Logic Board Disconnection: 步骤 5 中的图像 2,2
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  6. Logic Board Disconnection: 步骤 6 中的图像 1,3 Logic Board Disconnection: 步骤 6 中的图像 2,3 Logic Board Disconnection: 步骤 6 中的图像 3,3
    • Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
    • Slide the sound board cable out of the ZIF connector.
  7. Logic Board Disconnection: 步骤 7 中的图像 1,1
    • Peel back the black tape covering the fan cable connector.
  8. Logic Board Disconnection: 步骤 8 中的图像 1,3 Logic Board Disconnection: 步骤 8 中的图像 2,3 Logic Board Disconnection: 步骤 8 中的图像 3,3
    • Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
    • Slide the fan cable out of the ZIF connector.
  9. Logic Board Disconnection: 步骤 9 中的图像 1,2 Logic Board Disconnection: 步骤 9 中的图像 2,2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  10. Logic Board Disconnection: 步骤 10 中的图像 1,3 Logic Board Disconnection: 步骤 10 中的图像 2,3 Logic Board Disconnection: 步骤 10 中的图像 3,3
    • Insert the point of a spudger under one of the antenna cables close to the connector. Pry straight up to disconnect the cable.
    • Repeat for the other antenna cable.
  11. Logic Board Disconnection: 步骤 11 中的图像 1,2 Logic Board Disconnection: 步骤 11 中的图像 2,2
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket.
    • Remove the display cable connector bracket.
  12. Logic Board Disconnection: 步骤 12 中的图像 1,2 Logic Board Disconnection: 步骤 12 中的图像 2,2
    • Use the flat end of a spudger to pry up the display cable connector.
结论
Adam O'Camb
于04/11/15注册
217,431 声望
创作了416篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 223
