本指南有最近更改,您可查看未经巡查的最新版本。
简介
You will be desoldering and replacing the power connector.
你所需要的
Remove the rubber inserts inside the the two purple feet located on the router's front case.
This may be a challenge, so try the following two methods:
Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
Turn the circuit board over and identify the solder connections you will desolder.
The connections for the power connector are shown in red.
