跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
In this guide we will go over removing the top casing.
配件
没有特定配件。
  1. Power down and unplug the device.
    • Power down and unplug the device.
  2. Remove the antennas from the back of the device. To do this, follow steps 1 and 2 of      Installing the Antennas Guide: Linksys WAP54g Antennas Replacement
  3. Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  6. To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  7. Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  8. Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts. Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  9. From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes. Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
结论
From here you can take apart the rest of the router apart by following subsequent guides.
另外一个人完成了本指南。
Derek Myers
于2011年10月04日注册
282 信誉积分
创作了5篇指南
团队
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G21
5 名成员
创作了6篇指南
Bon Tutoriel. Simple, mais les plastiques sont solidement attacher. Il faut donc forcer pour démonter la partie bleu. Mais c’est possible.
Merci.
Philippe Gabriel - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 2
总计 1,280
