跳转到主内容
Linksys EA9200 Power Switch Replacement
你所需要的
  1. Linksys EA9200 Power Switch Replacement, Linksys EA9200 Disassembly: 步骤 1 中的图像 1,2 Linksys EA9200 Power Switch Replacement, Linksys EA9200 Disassembly: 步骤 1 中的图像 2,2
    • Remove the sticker on the bottom.
    • Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
  2. Linksys EA9200 Power Switch Replacement: 步骤 2 中的图像 1,2 Linksys EA9200 Power Switch Replacement: 步骤 2 中的图像 2,2
    • Remove the back sticker that has all the labels.
    • There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
  3. Linksys EA9200 Power Switch Replacement: 步骤 3 中的图像 1,3 Linksys EA9200 Power Switch Replacement: 步骤 3 中的图像 2,3 Linksys EA9200 Power Switch Replacement: 步骤 3 中的图像 3,3
    • Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
  4. Linksys EA9200 Power Switch Replacement: 步骤 4 中的图像 1,3 Linksys EA9200 Power Switch Replacement: 步骤 4 中的图像 2,3 Linksys EA9200 Power Switch Replacement: 步骤 4 中的图像 3,3
    • Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together.
    • These clips are tough and may need some additional force.
  5. Linksys EA9200 Power Switch Replacement: 步骤 5 中的图像 1,3 Linksys EA9200 Power Switch Replacement: 步骤 5 中的图像 2,3 Linksys EA9200 Power Switch Replacement: 步骤 5 中的图像 3,3
    • Lift the board and pull down, away from the antennas.
  6. Linksys EA9200 Power Switch Replacement, Power Switch: 步骤 6 中的图像 1,3 Linksys EA9200 Power Switch Replacement, Power Switch: 步骤 6 中的图像 2,3 Linksys EA9200 Power Switch Replacement, Power Switch: 步骤 6 中的图像 3,3
    • Desolder the 7 pins for the power switch from the backside of the circuit board.
    • In order to remove this part you will need a soldering iron that is capable of reaching temperatures greater than 300 degrees Fahrenheit.
    • 如何焊接和拆焊 is iFixit's official guide on how to use a soldering iron.
结论
Shane Davis
于10/05/16注册
374 声望
创作了3篇指南
团队
USF Tampa, Team 9-1, Lacy Fall 2016 USF Tampa, Team 9-1, Lacy Fall 2016 的会员
USFT-LACY-F16S9G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 535
