跳转到主内容
Likebook Muses Motherboard Replacement
你所需要的
  1. 注意:步骤 1-5 源自标记为进行中的 指南
    Likebook Muses Motherboard Replacement, Power off: 步骤 1 中的图像 1,1
    • Power off the tablet by holding down the power button (on the bottom) and tapping "Power off" on screen, then wait 10-15 seconds for the underlying Android system to shut down.
  2. Likebook Muses Motherboard Replacement, Rear Cover: 步骤 2 中的图像 1,1
    • Unscrew the two Torx T2 screws surrounding the USB port.
    • Image needed: showing just the bottom in order to highlight screws in blue
  3. Likebook Muses Motherboard Replacement: 步骤 3 中的图像 1,3 Likebook Muses Motherboard Replacement: 步骤 3 中的图像 2,3 Likebook Muses Motherboard Replacement: 步骤 3 中的图像 3,3
    • Use the opening tool to pry at the lip in between the bezel and rear cover,
    • then slide in your opening pick with the flat end,
    • and slide it around to undo these clips.
  4. Likebook Muses Motherboard Replacement: 步骤 4 中的图像 1,3 Likebook Muses Motherboard Replacement: 步骤 4 中的图像 2,3 Likebook Muses Motherboard Replacement: 步骤 4 中的图像 3,3
    • (Note to self: Try opening the side using opening tools)
    • After releasing the clips, lift the front bezel out.
    • The extension piece for the power button can fall out. Don't lose this!
  5. Likebook Muses Motherboard Replacement: 步骤 5 中的图像 1,1
    • The rear cover has been removed.
  6. Likebook Muses Motherboard Replacement, Mainboard: 步骤 6 中的图像 1,3 Likebook Muses Motherboard Replacement, Mainboard: 步骤 6 中的图像 2,3 Likebook Muses Motherboard Replacement, Mainboard: 步骤 6 中的图像 3,3
    • Disconnect the battery.
    • Due to the placement of the battery, the connector may not come out all the way.
  7. Likebook Muses Motherboard Replacement: 步骤 7 中的图像 1,3 Likebook Muses Motherboard Replacement: 步骤 7 中的图像 2,3 Likebook Muses Motherboard Replacement: 步骤 7 中的图像 3,3
    • Using the pointed end of a spudger, disconnect the touch panel.
  8. Likebook Muses Motherboard Replacement: 步骤 8 中的图像 1,3 Likebook Muses Motherboard Replacement: 步骤 8 中的图像 2,3 Likebook Muses Motherboard Replacement: 步骤 8 中的图像 3,3
    • Disconnect the pen input controller.
  9. Likebook Muses Motherboard Replacement: 步骤 9 中的图像 1,3 Likebook Muses Motherboard Replacement: 步骤 9 中的图像 2,3 Likebook Muses Motherboard Replacement: 步骤 9 中的图像 3,3
    • Lift up part of the tape covering the frontlight connector.
    • Using the flat end of your spudger, disconnect the display.
  10. Likebook Muses Motherboard Replacement: 步骤 10 中的图像 1,2 Likebook Muses Motherboard Replacement: 步骤 10 中的图像 2,2
    • Peel the tape the rest of the way
    • Using the pointed end of your spudger, disconnect the frontlight.
  11. Likebook Muses Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove these screws using your J00 screwdriver (or a PH00 screwdriver if you don't have one).
    • Remove these screws using your PH00 screwdriver.
    • One of these screws has a tamper detection sticker pasted over the screw head.
    • You should be able to poke the screwdriver through it.
  12. Likebook Muses Motherboard Replacement: 步骤 12 中的图像 1,1
    • Lift the mainboard out from the top,
    • The speaker connections are only held in with solder, and may break if you're not careful.
  13. Likebook Muses Motherboard Replacement: 步骤 13 中的图像 1,3 Likebook Muses Motherboard Replacement: 步骤 13 中的图像 2,3 Likebook Muses Motherboard Replacement: 步骤 13 中的图像 3,3
    • The mainboard has been removed.
结论
Kevin Bhasi
于12/26/14注册
1,262 声望
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 69
