跳转到主内容
Likebook Muses Rear Cover Replacement
你所需要的
  1. Likebook Muses Rear Cover Replacement, Power off: 步骤 1 中的图像 1,1
    • Power off the tablet by holding down the power button (on the bottom) and tapping "Power off" on screen, then wait 10-15 seconds for the underlying Android system to shut down.
  2. Likebook Muses Rear Cover Replacement, Rear Cover: 步骤 2 中的图像 1,1
    • Unscrew the two Torx T2 screws surrounding the USB port.
    • Image needed: showing just the bottom in order to highlight screws in blue
  3. Likebook Muses Rear Cover Replacement: 步骤 3 中的图像 1,3 Likebook Muses Rear Cover Replacement: 步骤 3 中的图像 2,3 Likebook Muses Rear Cover Replacement: 步骤 3 中的图像 3,3
    • Use the opening tool to pry at the lip in between the bezel and rear cover,
    • then slide in your opening pick with the flat end,
    • and slide it around to undo these clips.
  4. Likebook Muses Rear Cover Replacement: 步骤 4 中的图像 1,3 Likebook Muses Rear Cover Replacement: 步骤 4 中的图像 2,3 Likebook Muses Rear Cover Replacement: 步骤 4 中的图像 3,3
    • (Note to self: Try opening the side using opening tools)
    • After releasing the clips, lift the front bezel out.
    • The extension piece for the power button can fall out. Don't lose this!
  5. Likebook Muses Rear Cover Replacement: 步骤 5 中的图像 1,1
    • The rear cover has been removed.
结论
另外一个人完成了本指南。
Kevin Bhasi
于12/26/14注册
1,262 声望
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 9
总计 130
