跳转到主内容
Lighting: Replacing Light Emitting Diode
你所需要的
  1. Lighting: Replacing Light Emitting Diode, Light Emitting Diode: 步骤 1 中的图像 1,1
    • Using a plastic opening tool, remove the base of the Light Angel.
    • Insert the plastic opening tool between the base and the LED housing and pull outwards on the handle.
  2. Lighting: Replacing Light Emitting Diode: 步骤 2 中的图像 1,1
    • Using a Phillips head jeweler's screwdriver, remove the screw on the battery housing.
    • To remove the screw, turn counterclockwise.
    • Remember to put all the screws you take out somewhere safe so you can find them when it's time to reassemble the light.
  3. Lighting: Replacing Light Emitting Diode: 步骤 3 中的图像 1,1
    • Remove and set aside the (4) AA batteries in the battery housing.
  4. Lighting: Replacing Light Emitting Diode: 步骤 4 中的图像 1,1
    • Using a Phillips head jeweler's screwdriver, remove the (6) screws holding the LED housing together.
    • To remove the screws, turn counterclockwise.
  5. Lighting: Replacing Light Emitting Diode: 步骤 5 中的图像 1,1
    • Insert the plastic opening tool into the crease on the side of the LED housing to separate it from the rest of the device.
  6. Lighting: Replacing Light Emitting Diode: 步骤 6 中的图像 1,1
    • Locate the faulty light emitting diode on the back of the circuit board.
    • Using a soldering iron and desoldering braid, unsolder the connection on the light emitting diode.
    • Do not allow the soldering iron to come in contact with other components on the circuit board.
    • For detailed instructions on how to solder go to 如何焊接和拆焊
  7. Lighting: Replacing Light Emitting Diode: 步骤 7 中的图像 1,1
    • Insert the new light emitting diode through the two holes left from removing the old one.
    • Note: the picture is not of the Light Angel circuit board. It is a general example of inserting a light emitting diode on a circuit board. Photo Credit: 如何焊接和拆焊
  8. Lighting: Replacing Light Emitting Diode: 步骤 8 中的图像 1,1
    • Using solder and a soldering iron, solder the new LED to the circuit board.
    • Keep your solder joints separate to avoid short circuiting the circuit board.
结论
2等其他人完成本指南。
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 24
过去 30 天: 70
总计 6,078
