跳转到主内容
加入维修社区 - 创建账户
Lighting - Budget
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
  1. Lighting - Budget, Budget - Picking bulbs: 步骤 1 中的图像 1,3 Lighting - Budget, Budget - Picking bulbs: 步骤 1 中的图像 2,3 Lighting - Budget, Budget - Picking bulbs: 步骤 1 中的图像 3,3
    • Try and stick to >90+ CRI 5000-5500k (>90+ CRI) bulbs as these are more beginner-friendly; 6000-6500k bulbs often require heavier correction or a custom WB setting. For >80 CRI bulbs, a custom WB can help offset the poor light quality.
    • IF YOU HAVE OVEREXPOSURE ISSUES, set the exposure comp to -0.5-1.0 as needed. If this does not help, correct it in post.
    • CFL (AVOID): Avoid using CFLs, even on clearance. They are not as bright as LEDs, take time to warm up and contain mercury (disposal is hard). They also tend to fail young due to cheap ballasts and components that do not get along with heat.
    • BR30/40: These produce a focused beam of light which can result in better photos compared to omnidirectional bulbs. These bulbs must be used in a specific direction by design.
    • A19: While these work the light can be somewhat unbalanced or scattered without redirection. You must use a minimum of 100W for good photo lighting.
    • Multi-panel workshop lighting: These produce significantly more light than floodlights, but can only be used where weight is not an issue and well spaced to avoid overexposure.
  2. Lighting - Budget, Budget - Lighting setup: 步骤 2 中的图像 1,3 Lighting - Budget, Budget - Lighting setup: 步骤 2 中的图像 2,3 Lighting - Budget, Budget - Lighting setup: 步骤 2 中的图像 3,3
    • Items like inexpensive big box store tripods with missing parts can be "upcycled" to help reduce setup costs. It is also possible to use other items like "BER" lamps.
    • Side lighting
    • Tripod or light stands: If you can find a pair of quality tripods, these can often be used as makeshift light stands. High-end tripods are not required, but nice to have.
    • Standing lamp: Space may be an issue with lamps that have a base, but if you can make this work a broken lamp (with the cord and socket removed) can be used.
    • Edge cases
    • Over the top: This method requires specific setup conditions not always feasible without a dedicated workspace. However, this method can allow the use of one bright LED instead of 2 when it works (must use 1,500-2,000+ lumens).
    • Side clamping: This works in a pinch, but should be considered a last resort. Light placement may be restricted which can show in the final photo. Look into better options first.
结论
Nick
于11/10/09注册
99,421 声望
创作了63篇指南
团队
Master Techs Master Techs 的会员
Community
331 名成员
创作了1,458篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 59
