跳转到主内容
LexiBook Tablet One Speaker Replacement
你所需要的
  1. LexiBook Tablet One Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 LexiBook Tablet One Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 LexiBook Tablet One Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Insert the blue plastic opening tool where the case has a seam. Move side to side until you hear a clip pop. Move around the edge of the case until all clips are separated. The clips are 1.5 in. apart within the case.
  2. LexiBook Tablet One Speaker Replacement: 步骤 2 中的图像 1,2 LexiBook Tablet One Speaker Replacement: 步骤 2 中的图像 2,2
    • After successfully separating the casing insert a plastic spudger between the case and the speaker. Carefully pry the speaker out. Once the speaker is removed set the back casing aside.
  3. LexiBook Tablet One Speaker Replacement: 步骤 3 中的图像 1,1
    • Using a soldering gun, apply heat where the speaker wires meet the motherboard. Heat the solder around both the black and red wires until they easily slide away.
    • Be careful not to heat the motherboard too long so to avoid damaging other components. Also, care to avoid liquefying the solder on any near by components.
    • How to Solder is IFixIt's official guide to use a soldering gun.
结论
Jordan
于03/11/15注册
650 声望
创作了4篇指南
团队
Colorado Springs, Team 2-5, Panko Spring 2015 Colorado Springs, Team 2-5, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 213
