跳转到主内容
加入维修社区 - 创建账户
Lens Replacement
你所需要的
  1. Lens Replacement, Removing the Battery: 步骤 1 中的图像 1,3 Lens Replacement, Removing the Battery: 步骤 1 中的图像 2,3 Lens Replacement, Removing the Battery: 步骤 1 中的图像 3,3
    • Flip the small blue switch up to release the battery. Remove the battery.
    • Remove two Philips #000 screws. Place the screws on a magnetic pad or somewhere safe.
    • Insert a plastic opening tool in the corner by the Micro USB plug. This area will allow leverage in order to take off the outer case.
    询问修复机器人
    添加评论
  2. Lens Replacement, Removing the Outer Casing: 步骤 2 中的图像 1,3 Lens Replacement, Removing the Outer Casing: 步骤 2 中的图像 2,3 Lens Replacement, Removing the Outer Casing: 步骤 2 中的图像 3,3
    • Use the opening tool and your fingers to pry apart the outer case. Hold back camera as well as menu navigation buttons while you remove the case.
    • Unscrew two small Phillips screws holding the outer case to the motherboard. Use the opening tool to unhook the case from the plate covering the motherboard.
    • The second screw (top left) is under the control PCB. The PCB is mounted to a metal plate that is retained by some adhesive tape underneath and two prongs (bottom-left). You need to pry the plate from the top-right until the tape is broken, then slide the plate upwards (relative to photo). Take care not to pull or tear the ribbon cable.
    询问修复机器人
    添加评论
  3. Lens Replacement, Removing the Ribbon: 步骤 3 中的图像 1,2 Lens Replacement, Removing the Ribbon: 步骤 3 中的图像 2,2
    • Disconnect the button casing ribbon cable from the motherboard.
    • Be gentle when removing the ribbon.
    • Lift up the metal casing with one hand and use the other hand to snap the ZIF connector back, in order to remove the display ribbon cable.
    询问修复机器人
    添加评论
  4. Lens Replacement, Replacing the Lens: 步骤 4 中的图像 1,3 Lens Replacement, Replacing the Lens: 步骤 4 中的图像 2,3 Lens Replacement, Replacing the Lens: 步骤 4 中的图像 3,3
    • Remove the display and buttons.
    • Release the clamp on the two ribbon cables connected to the camera lens.
    • Be gentle when removing the ribbons cables. They are fragile and can tear.
    • Pull the lens out of the camera base.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
salome datong
于09/26/16注册
104 声望
撰写一个指南
团队
USF Tampa, Team 14-4, Eyestone Fall 2016 USF Tampa, Team 14-4, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S14G4
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 66
总计 1,986
