跳转到主内容
Lenovo Yoga C930-13IKB Touch Pad Replacement
你所需要的
  1. Lenovo Yoga C930-13IKB Touch Pad Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Touch Pad Replacement: 步骤 2 中的图像 1,2 Lenovo Yoga C930-13IKB Touch Pad Replacement: 步骤 2 中的图像 2,2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Touch Pad Replacement: 步骤 3 中的图像 1,2 Lenovo Yoga C930-13IKB Touch Pad Replacement: 步骤 3 中的图像 2,2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB Touch Pad Replacement, Battery: 步骤 4 中的图像 1,3 Lenovo Yoga C930-13IKB Touch Pad Replacement, Battery: 步骤 4 中的图像 2,3 Lenovo Yoga C930-13IKB Touch Pad Replacement, Battery: 步骤 4 中的图像 3,3
    • Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
    • Use the spudger for assistance.
  5. Lenovo Yoga C930-13IKB Touch Pad Replacement: 步骤 5 中的图像 1,1
    • Unscrew the four 3mm screws with a Phillips screwdriver.
  6. Lenovo Yoga C930-13IKB Touch Pad Replacement: 步骤 6 中的图像 1,2 Lenovo Yoga C930-13IKB Touch Pad Replacement: 步骤 6 中的图像 2,2
    • The battery is still held in place with two stretch-release adhesive strips, similar to ones found in an iPhone.
    • Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
    • Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
    • Repeat the procedure for the second strip on the opposite side of the battery.
    • Be careful not to bend the battery. Breaking the battery is dangerous.
    • Remove the battery with your hands.
  7. Lenovo Yoga C930-13IKB Touch Pad Replacement, Touch Pad: 步骤 7 中的图像 1,2 Lenovo Yoga C930-13IKB Touch Pad Replacement, Touch Pad: 步骤 7 中的图像 2,2
    • Unscrew the four 2 mm screws with a Phillips #00 screwdriver.
  8. Lenovo Yoga C930-13IKB Touch Pad Replacement: 步骤 8 中的图像 1,3 Lenovo Yoga C930-13IKB Touch Pad Replacement: 步骤 8 中的图像 2,3 Lenovo Yoga C930-13IKB Touch Pad Replacement: 步骤 8 中的图像 3,3
    • Carefully pull out the small electrical wire from the back of the touch pad.
  9. Lenovo Yoga C930-13IKB Touch Pad Replacement: 步骤 9 中的图像 1,2 Lenovo Yoga C930-13IKB Touch Pad Replacement: 步骤 9 中的图像 2,2
    • The touch pad must be slid out before being lifted out.
    • Lift up the touch pad.
    • Slide the touch pad out of the laptop.
结论
另外一个人完成了本指南。
Matteo
于01/23/20注册
97 声望
撰写一个指南
团队
Cal Poly, Team S19-G5, White Winter 2020 Cal Poly, Team S19-G5, White Winter 2020 的会员
CPSU-WHITE-W20S19G5
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 15
总计 803
