跳转到主内容
Lenovo Yoga 900-13ISK Display Assembly Replacement
你所需要的
  1. Lenovo Yoga 900-13ISK Display Assembly Replacement, Back Cover: 步骤 1 中的图像 1,2 Lenovo Yoga 900-13ISK Display Assembly Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Display Assembly Replacement, Battery: 步骤 3 中的图像 1,3 Lenovo Yoga 900-13ISK Display Assembly Replacement, Battery: 步骤 3 中的图像 2,3 Lenovo Yoga 900-13ISK Display Assembly Replacement, Battery: 步骤 3 中的图像 3,3
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 4 中的图像 1,3 Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 4 中的图像 2,3 Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 4 中的图像 3,3
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
  5. Lenovo Yoga 900-13ISK Display Assembly Replacement, Display Assembly: 步骤 5 中的图像 1,3 Lenovo Yoga 900-13ISK Display Assembly Replacement, Display Assembly: 步骤 5 中的图像 2,3 Lenovo Yoga 900-13ISK Display Assembly Replacement, Display Assembly: 步骤 5 中的图像 3,3
    • Remove the ten 3.6 mm screws from the hinge bracket with a Phillips #00 screwdriver.
  6. Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 6 中的图像 1,3 Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 6 中的图像 2,3 Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 6 中的图像 3,3
    • Use the pointed end of a spudger to lift the hinged locking flap of the display ZIF connector.
  7. Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 7 中的图像 1,2 Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Pull out the display cable with a pair of blunt nose tweezers.
  8. Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 8 中的图像 1,3 Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 8 中的图像 2,3 Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 8 中的图像 3,3
    • Open the laptop to a 45° angle, then close the laptop.
    • This raises the hinge, which will stay open as the bottom case is lowered.
  9. Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 9 中的图像 1,3 Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 9 中的图像 2,3 Lenovo Yoga 900-13ISK Display Assembly Replacement: 步骤 9 中的图像 3,3
    • Slide the bottom case away from the hinge.
    • If the hinge is catching on the case, either go back to the previous step and open the case a bit more, or manually open the hinge with your fingers.
结论
另外一个人完成了本指南。
Austin Blakely
于03/11/19注册
19,646 声望
创作了53篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,410篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 18
总计 851
