跳转到主内容
Lenovo Yoga 900-13ISK Battery Replacement
你所需要的
  1. Lenovo Yoga 900-13ISK Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 Lenovo Yoga 900-13ISK Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Battery Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga 900-13ISK Battery Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga 900-13ISK Battery Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Battery Replacement, Battery: 步骤 3 中的图像 1,3 Lenovo Yoga 900-13ISK Battery Replacement, Battery: 步骤 3 中的图像 2,3 Lenovo Yoga 900-13ISK Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Battery Replacement: 步骤 4 中的图像 1,3 Lenovo Yoga 900-13ISK Battery Replacement: 步骤 4 中的图像 2,3 Lenovo Yoga 900-13ISK Battery Replacement: 步骤 4 中的图像 3,3
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
另外一个人完成了本指南。
Austin Blakely
于03/11/19注册
19,640 声望
创作了53篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,303篇指南
一条评论
Phillips 00 will not fit the 5 screws in my computer!
Elaine Gelb - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 60
总计 2,696
