跳转到主内容
Lenovo Yoga 710-15ISK Battery Replacement
你所需要的
  1. Lenovo Yoga 710-15ISK Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 Lenovo Yoga 710-15ISK Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Flip your laptop over so the bottom is facing upwards.
    • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver.
  2. Lenovo Yoga 710-15ISK Battery Replacement: 步骤 2 中的图像 1,1
    • Pry the back cover off of the laptop with your fingers.
  3. Lenovo Yoga 710-15ISK Battery Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo Yoga 710-15ISK Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
  4. Lenovo Yoga 710-15ISK Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the connector between the battery and the motherboard by gently pulling the black plastic-coated part of the wires.
  5. Lenovo Yoga 710-15ISK Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the battery from the laptop.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
Elisa Normand
于10/25/21注册
423 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-5, Sinclaire Fall 2021 UMass Dartmouth, Team 3-5, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S3G5
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 17
总计 420
