跳转到主内容
Lenovo Yoga 6 13ALC6 Lower Case Replacement
你所需要的
  1. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Unfasten the lower case: 步骤 1 中的图像 1,2 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Unfasten the lower case: 步骤 1 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the six 7.2 mm screws securing the lower case.
  2. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Insert the opening pick: 步骤 2 中的图像 1,2 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Insert the opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the lower case and the chassis at a hinge corner.
    • Pry up with the pick to release the clips securing the lower case.
    • Repeat the process on the other hinge corner.
  3. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the clips: 步骤 3 中的图像 1,3 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the clips: 步骤 3 中的图像 2,3 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the clips: 步骤 3 中的图像 3,3
    • Slide the pick along the right edge to release the clips securing the lower case.
  4. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the remaining clips: 步骤 4 中的图像 1,3 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the remaining clips: 步骤 4 中的图像 2,3 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the remaining clips: 步骤 4 中的图像 3,3
    • Continue sliding the opening pick along the front and left edges to release the remaining clips.
  5. Lenovo Yoga 6 13ALC6 Lower Case Replacement: 步骤 5 中的图像 1,3 Lenovo Yoga 6 13ALC6 Lower Case Replacement: 步骤 5 中的图像 2,3 Lenovo Yoga 6 13ALC6 Lower Case Replacement: 步骤 5 中的图像 3,3
    • Insert the pick on the hinge edge and slide along the entire edge to release all of the clips.
  6. Lenovo Yoga 6 13ALC6 Lower Case Replacement: 步骤 6 中的图像 1,3 Lenovo Yoga 6 13ALC6 Lower Case Replacement: 步骤 6 中的图像 2,3 Lenovo Yoga 6 13ALC6 Lower Case Replacement: 步骤 6 中的图像 3,3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
结论
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Lenovo Yoga answers community for help.
Spencer Day
于09/14/22注册
55,176 声望
创作了408篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,420篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 73
总计 1,379
