跳转到主内容
Lenovo Yoga 3 11 Speaker Replacement
你所需要的
  1. Lenovo Yoga 3 11 Speaker Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Speaker Replacement, Battery: 步骤 2 中的图像 1,3 Lenovo Yoga 3 11 Speaker Replacement, Battery: 步骤 2 中的图像 2,3 Lenovo Yoga 3 11 Speaker Replacement, Battery: 步骤 2 中的图像 3,3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Speaker Replacement: 步骤 3 中的图像 1,1
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Speaker Replacement: 步骤 4 中的图像 1,2 Lenovo Yoga 3 11 Speaker Replacement: 步骤 4 中的图像 2,2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Speaker Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 Lenovo Yoga 3 11 Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    • Use a pair of tweezers to peel up one side of each of the 3 pieces of tape that cover the speaker wires.
  7. Lenovo Yoga 3 11 Speaker Replacement: 步骤 7 中的图像 1,2 Lenovo Yoga 3 11 Speaker Replacement: 步骤 7 中的图像 2,2
    • Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift the black tab up, and the cable should come free.
  8. Lenovo Yoga 3 11 Speaker Replacement: 步骤 8 中的图像 1,3 Lenovo Yoga 3 11 Speaker Replacement: 步骤 8 中的图像 2,3 Lenovo Yoga 3 11 Speaker Replacement: 步骤 8 中的图像 3,3
    • Remove the two 2 mm Phillips #0 screws securing the left speaker.
    • Remove the two 2 mm Phillips #0 screws securing the right speaker.
  9. Lenovo Yoga 3 11 Speaker Replacement: 步骤 9 中的图像 1,2 Lenovo Yoga 3 11 Speaker Replacement: 步骤 9 中的图像 2,2
    • Use a pair of tweezers to disconnect the speaker connector.
    • Gently lift the speakers free of the device.
结论
另外一个人完成了本指南。
Slade Fernandes
于08/27/15注册
532 声望
创作了3篇指南
团队
USF Tampa, Team 2-3, Blackwell Fall 2015 USF Tampa, Team 2-3, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S2G3
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 11
总计 1,202
