跳转到主内容
Lenovo Yoga 11e Chromebook Keyboard Replacement
你所需要的
  1. Lenovo Yoga 11e Chromebook Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • There will be 7 Philips head screws on the bottom which will need to be removed to gain access to the battery
    • NOTE: You may void your warranty completing this replacement
  2. Lenovo Yoga 11e Chromebook Keyboard Replacement: 步骤 2 中的图像 1,1
    • There are two screws that will need to be removed to access the keyboard.
  3. Lenovo Yoga 11e Chromebook Keyboard Replacement: 步骤 3 中的图像 1,2 Lenovo Yoga 11e Chromebook Keyboard Replacement: 步骤 3 中的图像 2,2
    • Next, flip the laptop over and open it up. The keyboard can be easily removed by pushing it back from the front. I suggest using a jimmy tool to slip into the tiny gap to push it back.
    • Look closely at the two images you'll notice a slight gap at the bottom if you did this step correctly
  4. Lenovo Yoga 11e Chromebook Keyboard Replacement: 步骤 4 中的图像 1,1
    • Pull slightly up from the keyboard but NOT all the way, the ribbon cable is still connected to the motherboard
  5. Lenovo Yoga 11e Chromebook Keyboard Replacement: 步骤 5 中的图像 1,3 Lenovo Yoga 11e Chromebook Keyboard Replacement: 步骤 5 中的图像 2,3 Lenovo Yoga 11e Chromebook Keyboard Replacement: 步骤 5 中的图像 3,3
    • Use a plastic pry tool to lift up the plastic clip holding down the ribbon cable. Be very gentle with it so it doesn't break
结论
Congratulations you’ve successfully removed the keyboard! To reassemble your device, follow these instructions in reverse order.
3等其他人完成本指南。
Corey Meyer
于05/01/17注册
2,292 声望
创作了2篇指南
团队
Kid fixers Kid fixers 的会员
Community
169 名成员
创作了225篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 32
总计 1,916
