跳转到主内容
Lenovo Yoga 11e Chromebook Battery Replacement
你所需要的
  1. Lenovo Yoga 11e Chromebook Battery Replacement, Removing the back panel: 步骤 1 中的图像 1,1
    • There will be 7 Philips head screws on the bottom which will need to be removed to gain access to the battery
    • NOTE: You may void your warranty completing this replacement
  2. Lenovo Yoga 11e Chromebook Battery Replacement, Removing the battery screws: 步骤 2 中的图像 1,1
    • There will be 2 other Philips screws under the cover there should also be two arrows pointing at each screw that needs to be removed.
  3. Lenovo Yoga 11e Chromebook Battery Replacement, Removing the battery: 步骤 3 中的图像 1,2 Lenovo Yoga 11e Chromebook Battery Replacement, Removing the battery: 步骤 3 中的图像 2,2
    • Pull up the battery slightly by the tab and pull back
    • Remove the connector from the motherboard and pull the battery up and away from the board
    • Make sure not to pull all the way back as the battery is still connected to the motherboard
    • The computer may not boot when you try to turn it on, plug it into its power supply and it should boot.
结论
Congratulations! You hopefully have successfully completed this guide! To reassemble your device follow the steps backwards.
4等其他人完成本指南。
Corey Meyer
于05/01/17注册
2,292 声望
创作了2篇指南
团队
Kid fixers Kid fixers 的会员
Community
169 名成员
创作了225篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 35
总计 3,129
