跳转到主内容
Lenovo YOGA 730-15IKB Wireless Card Replacement
你所需要的
  1. Lenovo YOGA 730-15IKB Wireless Card Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Lenovo YOGA 730-15IKB Wireless Card Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Wireless Card Replacement: 步骤 2 中的图像 1,2 Lenovo YOGA 730-15IKB Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Wireless Card Replacement: 步骤 3 中的图像 1,1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 1,1
    • Remove the sticky tape from the top edge of the wireless card.
  5. Lenovo YOGA 730-15IKB Wireless Card Replacement: 步骤 5 中的图像 1,3 Lenovo YOGA 730-15IKB Wireless Card Replacement: 步骤 5 中的图像 2,3 Lenovo YOGA 730-15IKB Wireless Card Replacement: 步骤 5 中的图像 3,3
    • Pull the black and white antenna wires off of the wireless card.
    • For reassembly, the white wire connects to the right terminal marked "1." The black wire connects to the left terminal marked "2."
  6. Lenovo YOGA 730-15IKB Wireless Card Replacement: 步骤 6 中的图像 1,2 Lenovo YOGA 730-15IKB Wireless Card Replacement: 步骤 6 中的图像 2,2
    • Remove one 2mm Phillips #1 screw.
  7. Lenovo YOGA 730-15IKB Wireless Card Replacement: 步骤 7 中的图像 1,2 Lenovo YOGA 730-15IKB Wireless Card Replacement: 步骤 7 中的图像 2,2
    • Pull the wireless card out of the socket at its resting angle.
    • Do not pull straight upward. Pull towards the hinges at the back of the laptop.
结论
Ellis Ruckman
于01/23/20注册
2,647 声望
创作了6篇指南
团队
Cal Poly, Team S1-G6, White Winter 2020 Cal Poly, Team S1-G6, White Winter 2020 的会员
CPSU-WHITE-W20S1G6
3 名成员
创作了27篇指南
1指南评论
I was able to use an intel AX210NGW WiFi 6 & BT 5.3 to work perfectly - plug and play. It worked at startup. I get download speeds nearly 1,000 Mb/s on a WiFi 6 network. Well worth the upgrade.
George - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 56
总计 3,758
