跳转到主内容
加入维修社区 - 创建账户
Lenovo YOGA 730-15IKB Heat Sink Replacement
你所需要的
  1. Lenovo YOGA 730-15IKB Heat Sink Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Lenovo YOGA 730-15IKB Heat Sink Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Heat Sink Replacement: 步骤 2 中的图像 1,2 Lenovo YOGA 730-15IKB Heat Sink Replacement: 步骤 2 中的图像 2,2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Heat Sink Replacement: 步骤 3 中的图像 1,1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Heat Sink Replacement, Left Fan: 步骤 4 中的图像 1,1
    • When the laptop is upside down, the left fan is on the right side of the laptop near the wireless card and the SSD.
    • Remove the black and white antenna wires from the groove on the right side of the fan.
  5. Lenovo YOGA 730-15IKB Heat Sink Replacement: 步骤 5 中的图像 1,2 Lenovo YOGA 730-15IKB Heat Sink Replacement: 步骤 5 中的图像 2,2
    • Disconnect the fan cable. Pull the wire toward the right side of the laptop while wiggling to loosen the connection.
    • You can also use the white tabs on the connector to push the cable free.
  6. Lenovo YOGA 730-15IKB Heat Sink Replacement: 步骤 6 中的图像 1,2 Lenovo YOGA 730-15IKB Heat Sink Replacement: 步骤 6 中的图像 2,2
    • Remove two 4mm Phillips #1 screws.
  7. Lenovo YOGA 730-15IKB Heat Sink Replacement: 步骤 7 中的图像 1,1
    • Pull the fan up and towards the front of the laptop.
  8. Lenovo YOGA 730-15IKB Heat Sink Replacement, Right Fan: 步骤 8 中的图像 1,1
    • When the laptop is upside down, the right fan is on the left side of the laptop near the large metal RAM cover.
    • Disconnect the fan cable. Pull the wire toward the back of the laptop while wiggling to loosen the connection.
  9. Lenovo YOGA 730-15IKB Heat Sink Replacement: 步骤 9 中的图像 1,2 Lenovo YOGA 730-15IKB Heat Sink Replacement: 步骤 9 中的图像 2,2
  10. Lenovo YOGA 730-15IKB Heat Sink Replacement: 步骤 10 中的图像 1,1
  11. Lenovo YOGA 730-15IKB Heat Sink Replacement, Heat Sink: 步骤 11 中的图像 1,3 Lenovo YOGA 730-15IKB Heat Sink Replacement, Heat Sink: 步骤 11 中的图像 2,3 Lenovo YOGA 730-15IKB Heat Sink Replacement, Heat Sink: 步骤 11 中的图像 3,3
    • Remove three 4mm Phillips #1 screws.
    • Do not remove the springs that are attached to the screws.
  12. Lenovo YOGA 730-15IKB Heat Sink Replacement: 步骤 12 中的图像 1,2 Lenovo YOGA 730-15IKB Heat Sink Replacement: 步骤 12 中的图像 2,2
    • Pull the heat sink up to remove it from the motherboard.
    • If the heat sink is not lifting up easily, try using an opening tool to gently pry the heat sink away from the motherboard. The thermal paste on the underside of the heat sink may be sticking to the motherboard.
    • It is good practice to always apply new thermal paste before reattaching the heat sink. See this guide for more instructions on using thermal paste.
结论
另外一个人完成了本指南。
Ellis Ruckman
于01/23/20注册
2,707 声望
创作了6篇指南
团队
Cal Poly, Team S1-G6, White Winter 2020 Cal Poly, Team S1-G6, White Winter 2020 的会员
CPSU-WHITE-W20S1G6
3 名成员
创作了27篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 33
总计 1,884
