跳转到主内容
Lenovo Thinkpad x230 Battery Replacement
你所需要的
  1. Lenovo Thinkpad x230 Battery Replacement, Preparations: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
  2. Lenovo Thinkpad x230 Battery Replacement, Locate the battery: 步骤 2 中的图像 1,1
    • Flip the computer upside down.
    • The red rectangle shows the location of the battery.
  3. Lenovo Thinkpad x230 Battery Replacement, Unlock the left switch: 步骤 3 中的图像 1,3 Lenovo Thinkpad x230 Battery Replacement, Unlock the left switch: 步骤 3 中的图像 2,3 Lenovo Thinkpad x230 Battery Replacement, Unlock the left switch: 步骤 3 中的图像 3,3
    • Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
  4. Lenovo Thinkpad x230 Battery Replacement, Remove the battery: 步骤 4 中的图像 1,3 Lenovo Thinkpad x230 Battery Replacement, Remove the battery: 步骤 4 中的图像 2,3 Lenovo Thinkpad x230 Battery Replacement, Remove the battery: 步骤 4 中的图像 3,3
    • Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
4等其他人完成本指南。
Johannes
于02/25/14注册
1,061 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 76
总计 6,703
