跳转到主内容
Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement
你所需要的
  1. Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement: 步骤 2 中的图像 1,1
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement, Speakers: 步骤 3 中的图像 1,3 Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement, Speakers: 步骤 3 中的图像 2,3 Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement, Speakers: 步骤 3 中的图像 3,3
    • Carefully unplug the speaker connector by pulling it towards you.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement: 步骤 4 中的图像 1,2 Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the two 5 mm screws on each speaker with a Phillips #1 screwdriver.
  5. Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement: 步骤 5 中的图像 1,2 Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement: 步骤 5 中的图像 2,2
    • Unweave the blue and white wires from underneath the plastic tabs connected to the battery.
  6. Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement: 步骤 6 中的图像 1,1
    • Lift each speaker up and out from the computer.
  7. Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement, Lithium Battery: 步骤 7 中的图像 1,3 Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement, Lithium Battery: 步骤 7 中的图像 2,3 Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement, Lithium Battery: 步骤 7 中的图像 3,3
    • Carefully lift the far end of the battery connector with an opening tool facing towards you.
    • Remove the connector by pushing it forward and lifting.
  8. Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement: 步骤 8 中的图像 1,2 Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement: 步骤 8 中的图像 2,2
    • Remove the central 5 mm screw with a Phillips #1 screwdriver.
  9. Lenovo Thinkpad X1 Carbon 4th Gen Lithium Battery Replacement: 步骤 9 中的图像 1,1
    • Lift the battery up and out of the computer.
结论
9等其他人完成本指南。
Alexander Davis
于01/23/20注册
1,114 声望
创作了7篇指南
团队
Cal Poly, Team S1-G4, White Winter 2020 Cal Poly, Team S1-G4, White Winter 2020 的会员
CPSU-WHITE-W20S1G4
3 名成员
创作了19篇指南
3条评论
Use a Phillips #0 not a #1 or P0 driver. It makes life a lot easier. ??
Jim Barbieri - 回复
Amazing skills learned for a beginner like me, thanks for this valuable knowledge!
Alberto Aquino - 回复
After replacing the battery, the laptop failed to boot. Following error is displayed: 1802: Unauthorized network card is plugged in - Power off and remove the network card (1199/9071). System is halted.
How to resolve this?
Pascal S - 回复
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 106
过去 30 天: 412
总计 22,364
