跳转到主内容
Lenovo Thinkpad X1 Carbon 4th Gen Coin Cell Replacement
你所需要的
  1. Lenovo Thinkpad X1 Carbon 4th Gen Coin Cell Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Lenovo Thinkpad X1 Carbon 4th Gen Coin Cell Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Coin Cell Replacement: 步骤 2 中的图像 1,1
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Coin Cell Replacement, Coin Cell Battery: 步骤 3 中的图像 1,2 Lenovo Thinkpad X1 Carbon 4th Gen Coin Cell Replacement, Coin Cell Battery: 步骤 3 中的图像 2,2
    • Peel back the plastic protective cover above the main battery section to expose the coin-cell's red and black wires.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Coin Cell Replacement: 步骤 4 中的图像 1,2 Lenovo Thinkpad X1 Carbon 4th Gen Coin Cell Replacement: 步骤 4 中的图像 2,2
    • Gently unplug the coin-cell wires from the connector by pulling horizontally away from the connector.
    • Lift the coin cell out from the computer.
结论
4等其他人完成本指南。
Alexander Davis
于01/23/20注册
1,114 声望
创作了7篇指南
团队
Cal Poly, Team S1-G4, White Winter 2020 Cal Poly, Team S1-G4, White Winter 2020 的会员
CPSU-WHITE-W20S1G4
3 名成员
创作了19篇指南
2条评论
Ive got a issue with my X1 Carbon not booting up . It will start up and tell me that my date and time is wrong but then it only gives me two choices Esc to continue or F1 to enter setup. Either way it takes me to a startup interrupt menu and then from there it takes me to boot menu where it says ATA HDDO: Toshiba it's a hard drive I'm guessing cuz it says it has 128 GB capacity. Again I'm faced with two choices because now I have boot menu and app menu, where do I fix this because my laptop is in great shape until all of this started.
Rick Hocutt - 回复
1st you have to confirm the boot to device, which is the toshiba drive. as it boots 2nd time, press esc again. it will now boot normally (to toshiba drive). you have to replace the coin battery, otherwise you will face that again when the laptop battery drains to 0%.
Peter Lim -
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 44
过去 30 天: 208
总计 6,317
