简介
Laptop batteries may become faulty after two years of use. A functioning battery is essential to an efficient laptop and is crucial to allowing the device to work as intended, which is as a portable computer. Old laptop batteries can be slow and not hold as much of a charge as a newer battery.
If you’ve owned your laptop for longer than two years, it may be time to replace the battery. Replacing the internal battery in the Lenovo ThinkPad T450 is a little more complex than replacing the external battery. Follow this guide to replace the internal battery in your laptop.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
你所需要的
Using your hands, slide the two locking tabs away from each other to release the battery.
Slide the battery up and out of the device.
Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
For optimal performance, after completing this guide, calibrate your newly installed battery.
