跳转到主内容
Lenovo Thinkpad T450 Internal Battery Replacement
你所需要的
  1. Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: 步骤 1 中的图像 1,3 Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: 步骤 1 中的图像 2,3 Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: 步骤 1 中的图像 3,3
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 Internal Battery Replacement, Back Cover: 步骤 2 中的图像 1,1
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 Internal Battery Replacement: 步骤 3 中的图像 1,3 Lenovo Thinkpad T450 Internal Battery Replacement: 步骤 3 中的图像 2,3 Lenovo Thinkpad T450 Internal Battery Replacement: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: 步骤 4 中的图像 1,2 Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: 步骤 4 中的图像 2,2
    • Using the JIS #00 screwdriver, remove the three 2.8 mm screws.
  5. Lenovo Thinkpad T450 Internal Battery Replacement: 步骤 5 中的图像 1,2 Lenovo Thinkpad T450 Internal Battery Replacement: 步骤 5 中的图像 2,2
    • Disconnect the battery cable from the motherboard using the plastic opening tool.
  6. Lenovo Thinkpad T450 Internal Battery Replacement: 步骤 6 中的图像 1,1
    • Lift up and remove the battery from the device.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
2等其他人完成本指南。
Justin Ogihara
于09/18/17注册
27,230 声望
创作了52篇指南
团队
EDU Team EDU Team 的会员
Staff
7 名成员
创作了637篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 30
过去 30 天: 162
总计 4,380
