跳转到主内容
Lenovo ThinkPad X280 Speaker Replacement
你所需要的
  1. Lenovo ThinkPad X280 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Speaker Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X280 Speaker Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Speaker Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad X280 Speaker Replacement: 步骤 3 中的图像 2,2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Speaker Replacement, Battery: 步骤 4 中的图像 1,3 Lenovo ThinkPad X280 Speaker Replacement, Battery: 步骤 4 中的图像 2,3 Lenovo ThinkPad X280 Speaker Replacement, Battery: 步骤 4 中的图像 3,3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 Speaker Replacement, Speakers: 步骤 5 中的图像 1,3 Lenovo ThinkPad X280 Speaker Replacement, Speakers: 步骤 5 中的图像 2,3 Lenovo ThinkPad X280 Speaker Replacement, Speakers: 步骤 5 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove two 5 mm screws from each speaker.
    • Once done, the speakers should still be attached with a red wire connecting to each other.
  6. Lenovo ThinkPad X280 Speaker Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad X280 Speaker Replacement: 步骤 6 中的图像 2,2
    • Using the black spudger, push the white plastic connector out of the the tan plug.
  7. Lenovo ThinkPad X280 Speaker Replacement: 步骤 7 中的图像 1,1
    • Remove speakers and wiring from device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 34
总计 1,384
