跳转到主内容
Lenovo ThinkPad X270 SSD Replacement
你所需要的
  1. Lenovo ThinkPad X270 SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,2 Lenovo ThinkPad X270 SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 2,2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo ThinkPad X270 SSD Replacement, Remove the micro SIM card tray: 步骤 2 中的图像 1,3 Lenovo ThinkPad X270 SSD Replacement, Remove the micro SIM card tray: 步骤 2 中的图像 2,3 Lenovo ThinkPad X270 SSD Replacement, Remove the micro SIM card tray: 步骤 2 中的图像 3,3
    • A SIM eject tool or bit isn't long enough to eject the tray.
    • Insert a straightened paper clip into the micro SIM card tray hole on the right edge of the laptop.
    • Press the paper clip firmly into the hole to eject the tray.
    • Remove the tray.
    • When reinserting the tray, slide the arms of the tray into the rectangular metal slot.
  3. Lenovo ThinkPad X270 SSD Replacement, Battery information: 步骤 3 中的图像 1,2 Lenovo ThinkPad X270 SSD Replacement, Battery information: 步骤 3 中的图像 2,2
    • Lay your laptop upside down to access the external battery.
    • Two sliding tabs secure the battery.
  4. Lenovo ThinkPad X270 SSD Replacement, Release the left tab: 步骤 4 中的图像 1,2 Lenovo ThinkPad X270 SSD Replacement, Release the left tab: 步骤 4 中的图像 2,2
    • Slide the left tab, labeled 1, to the unlocked position—it'll click into place and release the left side of the battery.
  5. Lenovo ThinkPad X270 SSD Replacement, Remove the battery: 步骤 5 中的图像 1,3 Lenovo ThinkPad X270 SSD Replacement, Remove the battery: 步骤 5 中的图像 2,3 Lenovo ThinkPad X270 SSD Replacement, Remove the battery: 步骤 5 中的图像 3,3
    • Hold the right tab, labeled 2, in the unlocked position and slide the battery out of its recess.
    • During reassembly, slide the battery into its recess until both tabs engage.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
  6. Lenovo ThinkPad X270 SSD Replacement, Unfasten the back cover: 步骤 6 中的图像 1,2 Lenovo ThinkPad X270 SSD Replacement, Unfasten the back cover: 步骤 6 中的图像 2,2
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
    • Don't try to completely remove the screws—they're secured to the back cover with delicate, plastic clips.
  7. Lenovo ThinkPad X270 SSD Replacement, Insert an opening pick: 步骤 7 中的图像 1,3 Lenovo ThinkPad X270 SSD Replacement, Insert an opening pick: 步骤 7 中的图像 2,3 Lenovo ThinkPad X270 SSD Replacement, Insert an opening pick: 步骤 7 中的图像 3,3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the bottom right edge of the back cover and frame.
    • Pry up the back cover to release the bottom right clips.
    • Leave the pick inserted in the bottom right corner.
  8. Lenovo ThinkPad X270 SSD Replacement, Release the bottom edge clips: 步骤 8 中的图像 1,3 Lenovo ThinkPad X270 SSD Replacement, Release the bottom edge clips: 步骤 8 中的图像 2,3 Lenovo ThinkPad X270 SSD Replacement, Release the bottom edge clips: 步骤 8 中的图像 3,3
    • During the next two steps, position your pick downward at a 45-degree angle to help release the clips.
    • Slide the pick to the bottom left corner to release the bottom clips.
  9. Lenovo ThinkPad X270 SSD Replacement, Release the left edge clips: 步骤 9 中的图像 1,2 Lenovo ThinkPad X270 SSD Replacement, Release the left edge clips: 步骤 9 中的图像 2,2
    • Insert your pick in the bottom left corner and slide the pick to the first USB port to release the left clips.
  10. Lenovo ThinkPad X270 SSD Replacement, Release the top corner clips: 步骤 10 中的图像 1,3 Lenovo ThinkPad X270 SSD Replacement, Release the top corner clips: 步骤 10 中的图像 2,3 Lenovo ThinkPad X270 SSD Replacement, Release the top corner clips: 步骤 10 中的图像 3,3
    • Insert an opening tool between the top left corner of the back cover and frame.
    • Pry the back cover up to release the clips securing its top left corner.
    • Repeat the process on the top right corner.
  11. Lenovo ThinkPad X270 SSD Replacement, Release the top edge clips: 步骤 11 中的图像 1,3 Lenovo ThinkPad X270 SSD Replacement, Release the top edge clips: 步骤 11 中的图像 2,3 Lenovo ThinkPad X270 SSD Replacement, Release the top edge clips: 步骤 11 中的图像 3,3
    • Five clips secure the top edge of the back cover.
    • Insert an opening tool in the gap between the back cover and frame, next to one of the clips.
    • Push the opening tool into the gap until the clip releases.
  12. Lenovo ThinkPad X270 SSD Replacement: 步骤 12 中的图像 1,3 Lenovo ThinkPad X270 SSD Replacement: 步骤 12 中的图像 2,3 Lenovo ThinkPad X270 SSD Replacement: 步骤 12 中的图像 3,3
    • Push the opening tool between the back cover and frame at different points along the top edge to release the remaining clips.
  13. Lenovo ThinkPad X270 SSD Replacement, Remove the back cover: 步骤 13 中的图像 1,3 Lenovo ThinkPad X270 SSD Replacement, Remove the back cover: 步骤 13 中的图像 2,3 Lenovo ThinkPad X270 SSD Replacement, Remove the back cover: 步骤 13 中的图像 3,3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  14. Lenovo ThinkPad X270 SSD Replacement, Disconnect the internal battery: 步骤 14 中的图像 1,3 Lenovo ThinkPad X270 SSD Replacement, Disconnect the internal battery: 步骤 14 中的图像 2,3 Lenovo ThinkPad X270 SSD Replacement, Disconnect the internal battery: 步骤 14 中的图像 3,3
  15. Lenovo ThinkPad X270 SSD Replacement, Unfasten the SSD enclosure: 步骤 15 中的图像 1,2 Lenovo ThinkPad X270 SSD Replacement, Unfasten the SSD enclosure: 步骤 15 中的图像 2,2
    • Use a Phillips screwdriver to remove the 3.7 mm‑long screw securing the SSD enclosure to the frame.
  16. Lenovo ThinkPad X270 SSD Replacement, Reposition the SSD enclosure: 步骤 16 中的图像 1,2 Lenovo ThinkPad X270 SSD Replacement, Reposition the SSD enclosure: 步骤 16 中的图像 2,2
    • Gently lay the SSD enclosure over the left edge of the laptop.
  17. Lenovo ThinkPad X270 SSD Replacement, Move the speaker cable: 步骤 17 中的图像 1,2 Lenovo ThinkPad X270 SSD Replacement, Move the speaker cable: 步骤 17 中的图像 2,2
    • Use a spudger or your fingers to reposition the black and red speaker cable so you can access the SSD cable's socket on the motherboard.
  18. Lenovo ThinkPad X270 SSD Replacement, Disconnect the SSD cable: 步骤 18 中的图像 1,3 Lenovo ThinkPad X270 SSD Replacement, Disconnect the SSD cable: 步骤 18 中的图像 2,3 Lenovo ThinkPad X270 SSD Replacement, Disconnect the SSD cable: 步骤 18 中的图像 3,3
    • Insert the point of a spudger under the metal locking clip that snaps around the perimeter of the SSD cable’s socket.
    • Swing the clip up and over the socket.
    • Gently pull the SSD cable straight out of its socket.
  19. Lenovo ThinkPad X270 SSD Replacement, Unfasten the SSD cover: 步骤 19 中的图像 1,2 Lenovo ThinkPad X270 SSD Replacement, Unfasten the SSD cover: 步骤 19 中的图像 2,2
    • Lay the SSD enclosure upside down on your work surface.
    • Use a Phillips screwdriver to remove the two 3.7 mm‑long screws securing the SSD cover.
  20. Lenovo ThinkPad X270 SSD Replacement, Remove the SSD cover: 步骤 20 中的图像 1,2 Lenovo ThinkPad X270 SSD Replacement, Remove the SSD cover: 步骤 20 中的图像 2,2
    • Remove the SSD cover.
  21. Lenovo ThinkPad X270 SSD Replacement, Unfasten the SSD: 步骤 21 中的图像 1,2 Lenovo ThinkPad X270 SSD Replacement, Unfasten the SSD: 步骤 21 中的图像 2,2
    • Use a Phillips screwdriver to remove the 3.1 mm‑long screw securing the SSD to its enclosure.
  22. Lenovo ThinkPad X270 SSD Replacement, Remove the SSD: 步骤 22 中的图像 1,3 Lenovo ThinkPad X270 SSD Replacement, Remove the SSD: 步骤 22 中的图像 2,3 Lenovo ThinkPad X270 SSD Replacement, Remove the SSD: 步骤 22 中的图像 3,3
    • Hold the SSD enclosure down firmly against your workspace with one hand and pull the SSD straight out of its socket with your other hand.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
结论
Check your repair by running hardware tests with Lenovo Diagnostics.
2等其他人完成本指南。
Spencer Day
于09/14/22注册
54,914 声望
创作了407篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,298篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 92
过去 30 天: 352
总计 2,780
