跳转到主内容
Lenovo ThinkPad X270 External Battery Replacement
你所需要的
  1. Lenovo ThinkPad X270 External Battery Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,2 Lenovo ThinkPad X270 External Battery Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 2,2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo ThinkPad X270 External Battery Replacement, Battery information: 步骤 2 中的图像 1,2 Lenovo ThinkPad X270 External Battery Replacement, Battery information: 步骤 2 中的图像 2,2
    • Lay your laptop upside down to access the external battery.
    • Two sliding tabs secure the battery.
  3. Lenovo ThinkPad X270 External Battery Replacement, Release the left tab: 步骤 3 中的图像 1,2 Lenovo ThinkPad X270 External Battery Replacement, Release the left tab: 步骤 3 中的图像 2,2
    • Slide the left tab, labeled 1, to the unlocked position—it'll click into place and release the left side of the battery.
  4. Lenovo ThinkPad X270 External Battery Replacement, Remove the battery: 步骤 4 中的图像 1,3 Lenovo ThinkPad X270 External Battery Replacement, Remove the battery: 步骤 4 中的图像 2,3 Lenovo ThinkPad X270 External Battery Replacement, Remove the battery: 步骤 4 中的图像 3,3
    • Hold the right tab, labeled 2, in the unlocked position and slide the battery out of its recess.
    • During reassembly, slide the battery into its recess until both tabs engage.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
结论
Check your repair by running hardware tests with Lenovo Diagnostics.
For optimal performance, calibrate your newly installed battery after completing this guide.
另外一个人完成了本指南。
Spencer Day
于09/14/22注册
54,795 声望
创作了407篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,269篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 40
总计 446
