跳转到主内容
Lenovo ThinkPad X1 Yoga Battery Replacement
你所需要的
  1. Lenovo ThinkPad X1 Yoga Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Lenovo ThinkPad X1 Yoga Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Lenovo ThinkPad X1 Yoga Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
  2. Lenovo ThinkPad X1 Yoga Battery Replacement, Speakers: 步骤 2 中的图像 1,1
    • Remove the five 4.5mm Phillips #1 screws that secure the battery.
  3. Lenovo ThinkPad X1 Yoga Battery Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
  4. Lenovo ThinkPad X1 Yoga Battery Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad X1 Yoga Battery Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad X1 Yoga Battery Replacement: 步骤 4 中的图像 3,3
    • Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
  5. Lenovo ThinkPad X1 Yoga Battery Replacement, Battery: 步骤 5 中的图像 1,3 Lenovo ThinkPad X1 Yoga Battery Replacement, Battery: 步骤 5 中的图像 2,3 Lenovo ThinkPad X1 Yoga Battery Replacement, Battery: 步骤 5 中的图像 3,3
    • Lift the plastic black strip cover that's laying over the battery connector.
    • Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
    • Gently pull the connector away from the battery to pull it out of the slot.
  6. Lenovo ThinkPad X1 Yoga Battery Replacement: 步骤 6 中的图像 1,1
    • Lift and remove the battery away from the computer.
结论
11等其他人完成本指南。
3条评论
Hello, I was able to install the battery on my X1 carbon, but the laptop is not detecting my battery. How to remove whitelisting on X1 carbon yoga 1st gen?
Delta Force - 回复
Did you find a solution for your problem? Because i have the same problem since i changed my battery :/
Sarah -
Very useful instructions. I was able to replace the battery without any problems. Thank you very much.
Carlos Oppenheimer - 回复
添加评论
浏览统计数据:
过去 24 小时: 38
过去 7 天: 167
过去 30 天: 816
总计 35,967
