跳转到主内容
Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement
你所需要的
  1. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: 步骤 1 中的图像 1,2 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: 步骤 1 中的图像 2,2
    • Orient the laptop so that it is bottom up, and the track pad is closet to you.
    • Unscrew the seven cover screws with a Phillips #00 head screwdriver. These screws will loosen but will stay attached to the cover.
    • Slide the blue opening pick along the side of the laptop and pry off the one clip on each side.
  2. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #00 head screwdriver, remove the 3mm screw holding the wireless adapter to the motherboard.
  3. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: 步骤 3 中的图像 3,3
    • Slide the chip to the right carefully until the wireless adapter pops out.
    • Disconnect the grey and black wires by lifting them off straight up until they pop off the wireless adapter.
    • The chip should be completely removed from the computer and you are done.
结论
团队
Cal Poly, Team S7-G3, Regan Winter 2020 Cal Poly, Team S7-G3, Regan Winter 2020 的会员
CPSU-REGAN-W20S7G3
4 名成员
创作了8篇指南
一条评论
Hi, does the Lenovo X1 Extreme Gen 1 support Wifi 6 or 6e? If so what which card?
I tried the:
"AX210NGW WiFi Card, Wi-Fi 6E 11AX Wireless Module Expand to 6GHz MU-MIMO Tri-Band Bluetooth 5.3 Internal Network Adapter for Laptop, Support Windows 10/11 64bit, M.2/NGFF"
Wifi worked but Bluetooth wasn't recognized.
Captainturk - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 50
总计 1,990
