跳转到主内容
Lenovo ThinkPad T560 Fan Replacement
你所需要的
  1. Lenovo ThinkPad T560 Fan Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 Fan Replacement: 步骤 2 中的图像 1,1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 Fan Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo ThinkPad T560 Fan Replacement, Battery: 步骤 3 中的图像 2,2
    • Disconnect the battery connector from the motherboard by pulling it out of the port.
  4. Lenovo ThinkPad T560 Fan Replacement: 步骤 4 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the five 3.5 mm screws securing the battery.
    • Remove the battery.
  5. Lenovo ThinkPad T560 Fan Replacement, Fan: 步骤 5 中的图像 1,3 Lenovo ThinkPad T560 Fan Replacement, Fan: 步骤 5 中的图像 2,3 Lenovo ThinkPad T560 Fan Replacement, Fan: 步骤 5 中的图像 3,3
    • Using the iFixit opening tool, unlatch the power button's connection to the motherboard.
    • Remove the ribbon cable from the connector.
  6. Lenovo ThinkPad T560 Fan Replacement: 步骤 6 中的图像 1,1
    • Unplug the fan from the motherboard.
  7. Lenovo ThinkPad T560 Fan Replacement: 步骤 7 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the four 3.5 mm screws securing the heatsink.
  8. Lenovo ThinkPad T560 Fan Replacement: 步骤 8 中的图像 1,1
    • Using the Phillips #0 screwdriver, unscrew the 3.5mm screw securing the fan to the case.
    • Remove the fan and conjoined heatsink.
结论
Jackson Reynolds
于02/27/22注册
517 声望
创作了5篇指南
团队
Clemson, Team 1-3, Hunter Spring 2022 Clemson, Team 1-3, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S1G3
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 729
