跳转到主内容
Lenovo ThinkPad T495 CPU Fan Replacement
你所需要的
  1. Lenovo ThinkPad T495 CPU Fan Replacement, Baseplate: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 CPU Fan Replacement: 步骤 2 中的图像 1,1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 CPU Fan Replacement, CPU Fan: 步骤 3 中的图像 1,2 Lenovo ThinkPad T495 CPU Fan Replacement, CPU Fan: 步骤 3 中的图像 2,2
    • Firmly grip the white plug between your fingers and pull it straight backwards, parallel to the motherboard, until the fan connector releases.
  4. Lenovo ThinkPad T495 CPU Fan Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to loosen the four captive screws.
    • Much like the back cover of the laptop, these four screws are not designed to be removed, and will stay attached to the fan as it is removed.
  5. Lenovo ThinkPad T495 CPU Fan Replacement: 步骤 5 中的图像 1,3 Lenovo ThinkPad T495 CPU Fan Replacement: 步骤 5 中的图像 2,3 Lenovo ThinkPad T495 CPU Fan Replacement: 步骤 5 中的图像 3,3
    • Lift the fan up and out to remove it.
    • Before you reinsert the fan, make sure to apply a pea-sized amount of thermal paste to the center of where the fan makes contact with the CPU. Check out this guide for more details.
结论
Christian Taylor
于03/28/22注册
523 声望
创作了6篇指南
团队
UMass Dartmouth, Team 1-6, Petersen Spring 2022 UMass Dartmouth, Team 1-6, Petersen Spring 2022 的会员
UMASSD-PETERSEN-S22S1G6
3 名成员
创作了7篇指南
2条评论
I just used your instructions just to remove the baseplate and clean the fan. Worked, thank you! :)
My T495 is the LTE version. I noticed that you have to remove the SIM card tray from its slot (located on the "back" side between the hinges) to easily remove the backplate. I thought maybe you would want to add that in your instruction.
Peter Kogler - 回复
Buenas, ya llevé mi ThinkPad t495 con Lenovo y quería preguntarles ¿Es normal que cuando agitas el portátil suene como un clic?
SERGIO ANTONIO MEDINA GARCIA - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 38
过去 30 天: 111
总计 1,676
