跳转到主内容
Lenovo ThinkPad T490 SSD Replacement
你所需要的
  1. Lenovo ThinkPad T490 SSD Replacement, Base Plate: 步骤 1 中的图像 1,1
    • Loosen the screws from the base plate.
    • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
    • These screws are captive - they will not fully come out after being unscrewed.
  2. Lenovo ThinkPad T490 SSD Replacement: 步骤 2 中的图像 1,1
    • Insert the iFixit opening tool into the space between the base plate and the chassis.
    • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
  3. Lenovo ThinkPad T490 SSD Replacement: 步骤 3 中的图像 1,1
    • Grab the edge of the cover and lift the cover away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  4. Lenovo ThinkPad T490 SSD Replacement, SSD: 步骤 4 中的图像 1,2 Lenovo ThinkPad T490 SSD Replacement, SSD: 步骤 4 中的图像 2,2
    • Grab the battery pull-tab at the top of the connector plugin.
    • Pull the connector straight out in the direction toward the cable.
  5. Lenovo ThinkPad T490 SSD Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the 3.7 mm Phillips screw securing the SSD.
  6. Lenovo ThinkPad T490 SSD Replacement: 步骤 6 中的图像 1,1
    • Disconnect the SSD from its socket.
    • If it requires excess force to remove, wiggle side to side while pulling.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
另外一个人完成了本指南。
1指南评论
Strongly recommend reading Lenovo's own "T490 and P43s Hardware Maintenance Manual", particularly section "1020 Base cover assembly" which gives a recommended order for prying open the clips. It's pretty easy to apply too much pressure in the wrong place and snap a clip, especially now the plastics in these laptops are getting older.
(It's also possible to remove power by changing a setting in the BIOS instead of unplugging the battery, Lenovo's guide also explains how to do this.)
projectgus - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 42
过去 30 天: 176
总计 1,861
